Having trouble evaluating these limits
  • Thread starter Thread starter Nitrate
    Limits
The discussion revolves around evaluating the limits of the function (x-4)/(x-2) as x approaches 2 from both the right (2^+) and the left (2^-). The user initially misinterprets the behavior of the function near the vertical asymptote at x = 2, mistakenly concluding that the limit approaches +∞ from the right. However, after clarification, it is established that as x approaches 2 from the right, (x-4) approaches -2, leading to the correct conclusion that the limit is -∞. The user also references Wolfram Alpha for verification, which confirms the correct limit values.
  • Understanding of limits in calculus
  • Familiarity with vertical asymptotes
  • Knowledge of rational functions
  • Ability to interpret graphical behavior of functions
  • Study the concept of vertical asymptotes in detail
  • Learn how to sketch graphs of rational functions to visualize limits
  • Explore the use of Wolfram Alpha for limit evaluations
  • Practice evaluating limits involving rational functions with vertical asymptotes
Students studying calculus, particularly those focusing on limits and asymptotic behavior of functions, as well as educators looking for examples to illustrate these concepts.
Nitrate
The limit as x approaches 2^+ of (x-4)/(x-2)
The limit as x approaches 2^- of (x-4)/(x-2)
Figured out that the domain is x ≠ 2, therefore 2 is a vertical asymptote
not sure where to input values/what to do really..
drawing a picture will help, i think.
I tried
lim
x→2+ (0+-4)/(0+-2)
but i keep getting + infinity
and I'm not even sure if that's how you approach this question.
Can anyone help?
Nitrate said:
I tried
lim
x→2+ (0+-4)/(0+-2)
Did you follow murmillo's suggestion?
As x approaches 2 from the right, what does the graph of y = (x - 4)/(x - 2) do?
As x approaches 2 from the left, what does the graph of y = (x - 4)/(x - 2) do?
I did not because I want to follow the method that my instructor used
i did however draw the asymptote
And what method is that?
That's what I'm trying to piece together.
there was something about 1. (+)/(0^-) = - infinity
2. (-)/(0^-1) = + infinity
3. (-2)/(0^+)= - infinity
4. (1)/(0^+) = infinity
it has worked so far for my previous examples such as:
lim
x→1+ (3/x-1)
Domain: x can not equal 1
V.A: x = 1
lim (3)/(0+-1) = + infinity
but it is not working for the example that I'm on and i don't know why
For \displaystyle \lim_{x\to2^+} \frac{x-4}{x-2}
As x approaches 2 from the right (from the positive x direction) x-2 → 0+, that is to say x-2 becomes very small, but is positive.
Also, as x approaches 2 from the right, x-4 is close to positive 2.
So this gives you (+2)/(0+) → +∞​
The limit as x → 2- can be handled similarly.
however, for the first limit, the answer in the back of the book comes up as -∞
and when i type the limit as x approaches 2^+ of (x-4)/(x-2) into wolfram alpha it also comes up as - infinity
http://www.wolframalpha.com/input/?i=the+limit+as+x+approaches+2^++of+(x-4)/(x-2)
can anyone else help?
DUH !
I made a mistake !
... , as x approaches 2 from the right, x-4 is close to -2 (negative 2).
Therefore, this gives you (-2)/(0+) → -∞
SammyS said:
DUH !
I made a mistake !
sorry, but I'm having trouble understanding why x-4 is close to -2
The whole statement is, when x is close to 2, x - 4 is close to -2.
You should still sketch a graph of the function. The intent wasn't meant to be a proof, but to enable you to have some insight as to what the limit should be.
finally got the concept!
thanks everyone :)
  • · Replies 26 ·
