Hawaii's Kilauea volcano eruption
  • Thread starter davenn
    Volcano
126 replies · 49K views · last reply
We were in Hawaii last year (Maui and Kuai'i) and I got very interested in the geology of the chain. The big Island is still being born and is Lihu (sp?) which has many thousands of years before it breaks the surface and becomes the next Hawaiian island. In fact, it seems to take about 800,000 years to make one, then the island goes into a period of weathering, erosion and even collapse. Kuai'i is the oldest at about 8,000,000. It was formed by an initial vast shield volcano (like Haleakala on Maui) and sloughed off about half it's volume back to the sea due to its immense unsupportable bulk, only to be supplanted by a later volcano. The fissure between the lavas of these two distinct volcanoes formed the Waimea Canyon. Only later did the Waimea River carve its way on the bottom.
Maui is the next newest island that was composed of two shield volcanoes. Haleakala is the newest and is still in it's volcanic form, whereas the other is worn away, broken up and appears as a series of very green peaks that were originally just one large cone. (similar formations are found in the San Francisco peaks above Flagstaff, AZ, which was a vast 25,000 foot mountain that blew up like Mt. St. Helens, only worse, and what was left was a huge, jagged caldera that now has it's own name and appearance.
The Pacific Plate passes over the mid-plate hot spot and each island in turn gets its chance to be created, and then move on to leave room for its siblings. So… the Big Island isn't done yet and won't be for probably 200,000 years (wild guess considering how much it is above the water level and the highest elevation on the island). The island chain is sitting in 16,000 feet of water so it's a big deal when the shield volcano is big enough to brake the surface. Haleakala is therefore a 26,000 foot high volcanic mountain. Kuai'i's was probably higher initially (16,000 feet below sea level and 10,000 feet above).
Why I am giving this Hawaii geology lesson (besides wanting to show off what I learned from my book) is that building homes on an island that is still in the process of its birth seems like folly and it may be best to not build any more subdivisions, at least for a couple hundred thousand years. Incidentally, the actual chain is over 1,600 miles long and includes Midway. As the islands move on this "Pacific Conveyor Belt" they eventually end up sub-ducted somewhere in the Aleutians. Long before that, the islands wear away, become coral reefs and atolls and then disappear below the waves. The Hawaiian Islands will return to the magma that created them in about 80,000,000 years. So anybody wanting a long-term real estate investment, should probably look elsewhere.
I've been hearing lots of talk on news about the possibility of a steam explosion involving groundwater. I was confused by explanations of the lava lake level dropping down to the water table and generating steam. If the lava lake is already above the water table and fed by a tube, mustn't that feed go through the water?
Looking into it, I found a USGS explanation that described what happened in the 1924 explosion at the site. In brief, the water near the lava column is driven away by the heat. If the lava drops below the water level, water can flow into and become vaporized. If the conduit gets blocked by debris, it can result in a steam explosion.
Yes, that is correct.
The other cause you need to also consider is as the magma is forcing its was eastward, through existing and also creating new fissures
and penetrating existing pockets of water which would also create steam explosions.
Dave
Update
As of the 14th May, a new fissure has opened up further east of the existing fissures.
This is fissure #17 and at some 300m long is larger than the previous ones.
It is showing lava fountaining and some flows away from the fissure
Aerial photo of an active lava flow, glowing orange and red through dark cooled crust, moving through dense green forest with a large white plume of volcanic steam rising beside it.
Aerial photo of a lava flow from a fissure, with bright orange molten lava and fountaining, dark cooled crust, and white and grey volcanic gas plumes rising over green forest.
Aerial views of the 1,000-foot-long fissure that erupted on Kilauea's east rift zone on Sunday morning near Pahoa, Hawaii. Seventeen fissures have been reported in and around the Leilani Estates neighbourhood. (Bruce Omori/Paradise Helicopters / Bruce Omori/Paradise Helicopters)
http://www.latimes.com/nation/la-na-hawaii-kilauea-fissure-20180513-story.html
My edit ... Seventeen is the correct number
Dave
  • Aerial photo of an active lava flow, glowing orange and red through dark cooled crust, moving through dense green forest with a large white plume of volcanic steam rising beside it.
  • Aerial photo of a lava flow from a fissure, with bright orange molten lava and fountaining, dark cooled crust, and white and grey volcanic gas plumes rising over green forest.
    http%3A%2F%2Fprod.static9.net.au%2F_%2Fmedia%2F2018%2F05%2F14%2F08%2F08%2FHawaii-volcano.jpg
Well. my flight for Maui leaves in just a few hours. If all goes to plan, I'll arrive on the Big Island on Saturday. If there is a steam/ash explosion while I'm there, that will be the second time in my life of being within 50 miles or so of such an event. (I lived some 40 miles as the crow flies from St. Helens when she blew in '80.) That last one indirectly led to my getting 10 stitches on the top of my head, so let's keep our fingers crossed :nb). If something does happen while I'm there, If possible, I'll post an update. But it will likely be brief. I don't have an unlimited data plan on my phone, and unfortunately my hotel in Kona doesn't have free wi-fi ( and I'm not paying for it).
You should have told us earlier, as I would have started a Go-Fund-Janus page for you!
hmmm... How much is the WiFi? If it's less than $100, I'll wire you the funds.
As I mentioned earlier, I've never been to the big island.
But I've watched at least 3 hours of videos, and read up on the history of recent (past 100 years) eruptions, and now appreciate that someone who has never been there, has no clue what they are talking about. [I'm referring to myself, of course]
OmCheeto said:
I finally figured out why I was confused about what "Kilauea" meant.
It's a region.
Map of Hawai'i island showing five volcanic regions labelled Kohala, Mauna Kea, Hualālai, Mauna Loa and Kīlauea, with Kīlauea highlighted in pale yellow on the southeast coast; scale bar in miles and kilometres.
Om ... I meant to comment on this bit of the post of yours ...
Not so much a region but a particular volcano. Kilauea is one of 5 volcanoes on the Big Island. Kohala being the oldest and they get progressively younger towards the SE of the island. Mauna Loa is considered dormant with a possibility of future eruption. Kilauea is the youngest and still active.
The area highlited in yellow is the area over which the lava flows from Kilauea have been covering.
The Kilauea lava doesn't flow the other direction ( to the NW) because the land rises up in that direction as you head towards the summit ridge of Mauna LoaDave
  • Map of Hawai'i island showing five volcanic regions labelled Kohala, Mauna Kea, Hualālai, Mauna Loa and Kīlauea, with Kīlauea highlighted in pale yellow on the southeast coast; scale bar in miles and kilometres.
What makes them separate Dave?
I would guess its based on their tubes going down separately to some depth.
Do they join together at a single hot blob?
Are the others connected to cooled down hot blobs?
I'm not sure about Kohala, but the other four volcanoes are all considered active. Only Kilauea is currently erupting.
OmCheeto said:
...someone who has never been there, has no clue what they are talking about.
It's like reading stuff in a textbook; "Blah, blah, blah. Numbers, numbers, numbers."
And then you stop and look at the numbers, and go; "wow..."
Diagram comparing the depth of Pu'u 'O'o crater with the height of the Space Needle in Seattle; a photo of the tower is placed inside a deep grey crater cross-section, labelled 1150 feet deep and 600 feet tall.
Side-by-side comparison of a glowing lava fountain beside the One World Trade Center tower, with a quote from USGS giving 1,900 feet and 1900 feet labels, and 1776 feet beside the tower.
And there's been only one person killed in the last 94 years.
And he was an idiot, IMHO; "The last serious eruption in 1924 resulted in one fatality, when a photographer ventured too close to the action."
  • Diagram comparing the depth of Pu'u 'O'o crater with the height of the Space Needle in Seattle; a photo of the tower is placed inside a deep grey crater cross-section, labelled 1150 feet deep and 600 feet tall.
  • Side-by-side comparison of a glowing lava fountain beside the One World Trade Center tower, with a quote from USGS giving 1,900 feet and 1900 feet labels, and 1776 feet beside the tower.
They were/are all fed from the same hotspot (magma source). As the Pacific Plate motion carries the ocean floor over that hotspot,
the upwelling magma produces new volcanoes that eventually break the sea surface and produce islands. Of course, that motion is pretty small, 5 – 10 centimeters (2.0–3.9 in) a year, so multiple vents can produce a large island.
Cross-section diagram of the Hawaiian hotspot: Pacific Plate moves NW over a mantle plume, with island ages Ni'ihau/Kaua'i 5.6-4.9 Ma, O'ahu 3.4 Ma, Moloka'i 1.8 Ma, Maui 1.3 Ma, Hawai'i 0.7-0 Ma, and volcanoes Mauna Loa, Kilauea, Lo'ihi.
credit USGS
not quite ... see below :smile:
I wanted to find some dates for the different vents ...
from Wiki or USGS
Kohala is the oldest of five volcanoes that make up the island of Hawaii. Kohala is an estimated one million years old—so old that it experienced, and recorded, the reversal of earth's magnetic field 780,000 years ago. It is believed to have breached sea level more than 500,000 years ago[1] and to have last erupted 120,000 years ago. Kohala is 606 km2 (234 sq mi) in area and 14,000 km3 (3,400 cu mi) in volume, and thus constitutes just under 6% of the island of Hawaii
Mauna Kea (/ˌmɔːnə ˈkeɪ.ə/ or /ˌmaʊnə ˈkeɪ.ə/, Hawaiian: [ˈmɐwnə ˈkɛjə]) is a dormant volcano on the island of Hawaii. Standing 4,207 m (13,802 ft) above sea level, its peak is the highest point in the state of Hawaii making the island of Hawaii the second highest island in the world. Most of the mountain is underwater; when measured from its oceanic base, Mauna Kea is over 10,000 m (33,000 ft) tall and is the tallest mountain on Earth. Mauna Kea is about a million years old, and has thus passed the most active shield stage of life hundreds of thousands of years ago. In its current post-shield state, its lava is more viscous, resulting in a steeper profile. Late volcanism has also given it a much rougher appearance than its neighboring volcanoes; contributing factors include the construction of cinder cones, the decentralization of its rift zones, the glaciation on its peak, and the weathering effects of the prevailing trade winds. Mauna Kea last erupted 6,000 to 4,000 years ago and is now considered dormant.
Hualālai (pronounced [huwəˈlaːlɐi] in Hawaiian) is an active volcano on the island of Hawaiʻi in the Hawaiian Islands.[4] It is the westernmost, third-youngest and the third most active of the five volcanoes that form the island of Hawaiʻi, following Kīlauea and the much larger Mauna Loa. Its peak stands 8,271 feet (2,521 m) above sea level. Hualālai is estimated to have risen above sea level about 300,000 years ago. Despite maintaining a very low level of activity since its last eruption in 1801, and being unusually inactive for the last 2,000 years, Hualālai is still considered active, and is expected to erupt again some time within the next century. The relative unpreparedness of the residents in the area caused by the lull in activity would worsen the consequences of such an event.
Mauna Loa (/ˌmɔːnə ˈloʊ.ə/ or /ˌmaʊnə ˈloʊ.ə/; Hawaiian: [ˈmɐwnə ˈlowə]; English: Long Mountain[3]) is one of five volcanoes that form the Island of Hawaii in the U.S. state of Hawaiʻi in the Pacific Ocean. The largest subaerial volcano in both mass and volume, Mauna Loa has historically been considered the largest volcano on Earth, dwarfed only by Tamu Massif. It is an active shield volcano with relatively gentle slopes, with a volume estimated at approximately 18,000 cubic miles (75,000 km3),[4] although its peak is about 120 feet (37 m) lower than that of its neighbor, Mauna Kea. Lava eruptions from Mauna Loa are silica-poor and very fluid, and they tend to be non-explosive.
Mauna Loa has probably been erupting for at least 700,000 years, and may have emerged above sea level about 400,000 years ago. The oldest-known dated rocks are not older than 200,000 years.[5] The volcano's magma comes from the Hawaii hotspot, which has been responsible for the creation of the Hawaiian island chain over tens of millions of years. The slow drift of the Pacific Plate will eventually carry Mauna Loa away from the hotspot within 500,000 to one million years from now, at which point it will become extinct.
Mauna Loa's most recent eruption occurred from March 24 to April 15, 1984. No recent eruptions of the volcano have caused fatalities, but eruptions in 1926 and 1950 destroyed villages, and the city of Hilo is partly built on lava flows from the late 19th century. Because of the potential hazards it poses to population centers, Mauna Loa is part of the Decade Volcanoes program, which encourages studies of the world's most dangerous volcanoes. Mauna Loa has been monitored intensively by the Hawaiian Volcano Observatory since 1912. Observations of the atmosphere are undertaken at the Mauna Loa Observatory, and of the Sun at the Mauna Loa Solar Observatory, both located near the mountain's summit. Hawaii Volcanoes National Park covers the summit and the southeastern flank of the volcano, and also incorporates Kīlauea, a separate volcano.
Kīlauea (/ˌkiːlaʊˈeɪə/, US: /ˌkɪləˈweɪə/; Hawaiian: [tiːlɐwˈwɛjə]) is a currently active shield volcano in the Hawaiian Islands, and the most active of the five volcanoes that together form the island of Hawaiʻi. Located along the southern shore of the island, the volcano is between 300,000 and 600,000 years old and emerged above sea level about 100,000 years ago.
It is the second youngest product of the Hawaiian hotspot and the current eruptive center of the Hawaiian–Emperor seamount chain. Because it lacks topographic prominence and its activities historically coincided with those of Mauna Loa, Kīlauea was once thought to be a satellite of its much larger neighbor. Structurally, Kīlauea has a large, fairly recently formed caldera at its summit and two active rift zones, one extending 125 km (78 mi) east and the other 35 km (22 mi) west, as an active fault of unknown depth moving vertically an average of 2 to 20 mm (0.1 to 0.8 in) per year.
Kīlauea has been erupting nearly continuously since 1983 and has caused considerable property damage, including the destruction of the town of Kalapana in 1990. On May 3, 2018, several lava vents opened in the lower Puna area, downrift from the summit. The new volcanic episode was accompanied by a strong earthquake of Mw 6.9, and nearly 2,000 residents were evacuated from Leilani Estates and the adjacent Lanipuna Gardens development. By May 9, 2018 the eruption had destroyed 27 houses in the Leilani Estates subdivision.
So two classed as dormant and three classed as active ( having erupted in the last ~200 years)Dave
  • Cross-section diagram of the Hawaiian hotspot: Pacific Plate moves NW over a mantle plume, with island ages Ni'ihau/Kaua'i 5.6-4.9 Ma, O'ahu 3.4 Ma, Moloka'i 1.8 Ma, Maui 1.3 Ma, Hawai'i 0.7-0 Ma, and volcanoes Mauna Loa, Kilauea, Lo'ihi.
I don't have a feeling for the depth at which these things are occurring.
How deep are:
  • the magma chambers vs. the bottom of the crust?
  • magma chambers of different neighboring volcanoes vs. distance between the neighboring volcanoes?
  • length/depth of the sideways plumbing connecting the big volcano caldera pool with the vents that are active now?
How deep are:
  • magma chambers of different neighbouring volcanoes vs. distance between the neighbouring volcanoes?
just some round figures
1) the magma chambers vs. the bottom of the crust?
The magma chambers, for the most part, are between the top of the oceanic crust ( the lithosphere is that above diag.) and the top of each volcano.
So they are relatively shallow. The oceanic crust (the lithosphere) is a relatively constant ~ 10km thick. But you can see as the diag. hints at, how the mass of the islands depresses the crust
2) magma chambers of different neighbouring volcanoes vs. distance between the neighbouring volcanoes?
On the Big Island ? or are referring to the extinct ones as well on the islands to the west ?
The individual magma chambers are pretty much directly below each vent. Tho one large chamber may feed several vents.
You could use Google Earth and its measuring app to measure horizontal distances between the centres of the various vents, for both between those on the Big Island and between them and those on the other Hawaiian Islands to the west
eg. one I just did for the Big Island vents ...
Satellite map of the Island of Hawaii with yellow lines linking Kohala, Mauna Kea, Hilo, Kilauea, Mauna Loa, Hualālai and Kailua-Kona, labelled 82km, 53km, 50km, 36km and 46km.
3) length/depth of the sideways plumbing connecting the big volcano caldera pool with the vents that are active now?
I would have to do some searching for that info ... there probably has been some mapping done of underground structures using earthquakesDave
  • Satellite map of the Island of Hawaii with yellow lines linking Kohala, Mauna Kea, Hilo, Kilauea, Mauna Loa, Hualālai and Kailua-Kona, labelled 82km, 53km, 50km, 36km and 46km.
Great!
So something like 10 km down but separated by 3-5 times that distance.
Seem pretty well separated.
In thinking that the vertical scales of these diagrams are usually exaggerated vs. the horizontal scale.
Then the shape of the blobs would be much more flattened, as if they came up and stopped at some layer for whatever reason. Is that the case?
Of course they may just be artistic shapes.
I would estimate around half that ... 3 to 5 km
OK here we go, I was in the ball park :wink: from Wiki ...
Simplified geophysical models of Mauna Loa's magma chamber have been constructed, using interferometric synthetic aperture radar measures of ground deformation due to the slow buildup of lava under the volcano's surface. These models predict a 1.1 km (1 mi) wide magma chamber located at a depth of about 4.7 km (3 mi), 0.5 km (0 mi) below sea level, near the southeastern margin of Mokuʻāweoweo. This shallow magma chamber is significantly higher-placed than Mauna Loa's rift zones, suggesting magma intrusion into the deeper and occasional dike injections into the shallower parts of the rift zone drive rift activity; a similar mechanism has been proposed for neighboring Kīlauea.[25] Earlier models based on Mauna Loa's two most recent eruptions made a similar prediction, placing the chamber at 3 km (1.9 mi) deep in roughly the same geographic position.[26]
I doubt that the magma chambers for the other vents vary too much from those of Mauna LoaD
So, I am considering these volcano concepts (tell me what I got wrong):
1) different volcanos have separate plumbing systems for thee magma, if one part is draining to another part, they are of the same volcano.
2) Different volcanos would seem to be spatially separate from each other at the level of their hot magma load coming up from the mantle as separate events (but probably with a larger more distant common source, like a hot plume).
3) In Kileuea (see map, from here), magma can flow under ground through cracks (perhaps areas of weakness) of some kind (very linear on the map), before coming up to the surface. I guess these would be close to the surface.
USGS map of Kilauea Volcano East Rift Zone updated May 15, showing 2018 lava flows in red, past flows in purple, steepest descent paths in blue, and labeled towns, roads and the Fissure 17 flow front.
I wouldn't call these lava tubes (issue with relatives) because they are pre-made in the ground rather than a solidified surface of a flow of lava, but maybe I'm wrong.
What about possible Manipulations:
1935 Bombing of lava tubes to expose a flow to greater cooling is claimed to have saved Hilo.
However, its effectiveness has been disputed.
1) Would that be legal in HI these days?
2) I could see some other possible purposes:
  • Trying to direct a surface flow; like making a trench for it flow in, or making a berm.
  • Trying to greatly increase flow out at one place to alleviate pressure on the whole system in a controlled manner, say at a location where the flow would go right into the ocean (the blue lines in the map above are the lines of greatest fall, paths surface lava should like to follow).
  • Trying to create fractures (fracking or putting bombs down drilled holes) to direct the underground flows).
Do people do any of these these days?
  • USGS map of Kilauea Volcano East Rift Zone updated May 15, showing 2018 lava flows in red, past flows in purple, steepest descent paths in blue, and labeled towns, roads and the Fissure 17 flow front.
1) yes, and that is what is happening here. The magma is moving eastwards through the rift system, the result of which is that magma is draining from the main caldera of Kilauea
The vents/feed system of the eastern area of the island ( the Kilauea volcano) is quite complex. It isn't the ummm, "reasonably typical" one or 2 feed tubes branching off from the magma chamber. This is because of all the rifting that is giving magma many, many possible paths with which to push through on the way to the surface.
2) Don't forget that the Hawai'ian Is. chain and hotspot spot is reasonably unique. It is one of only a tiny number of hotspot volcanoes that can be easily observed on land. 99% of them are under sea in various places around the world.
The majority of land based volcanoes seen around the world are the result of subduction zone tectonics and mantle plumes and the like are not a factor.
The magma isn't coming up from the mantle, rather it is a melt produced from the mix of subducting oceanic floor and continental crust. This is why these type of volcanoes are more explosive than the Hawai'ian ones.
BillTre said:
3) In Kilauea (see map, from here), magma can flow under ground through cracks (perhaps areas of weakness) of some kind (very linear on the map), before coming up to the surface. I guess these would be close to the surface.
3) Yes, they do come up close to the surface. In one of those links above, can't remember which, there are comments that the rifting and fissures also go very deep.
The rifting and fissures really do aid in the propagation of magma into other areas.
From what I have read and understand, there is much more rifting associated with the eastern side of the Big Island that on the other side.
And that leads to one of the big concerns for the SE side of the island of a flank collapse along the Eastern Rift sections on the SE side of the Kilauea Volcano.
here's some interesting stuff …..
https://hilo.hawaii.edu/~kenhon/GEOL205/Flank/default.htm
https://agupubs.onlinelibrary.wiley.com/doi/full/10.1029/2007JB005124
Correct, lava tubes are a very specific thing and are formed from the flow of lava/magma. The last time I was in Hawai'i, my mate from Kona took me to a big lava tube NW of Kona. It is accessible from the side of the road and isn't overly old. was formed during one of the last lava flows from the Hulalai Volcano.
A lot of the tube was around 3 - 4 metres in diameter … I'm almost 2 metres tall (6'4") so I could walk through much of it without ducking my head.
Do people do any of these, these days?
1) Would that be legal in HI these days? …. probably not , imagine the public uproar. Apart from that, would you want to take responsibility if the activity caused a huge increase in volcanic activity ? Considering the flank instability of the Eastern Rift Zone,
it could induce a major disaster.
I know of only two cases where active efforts were done to divert lava flows...
1) In the Iceland Island of Heimaey, 1973
https://pubs.usgs.gov/of/1997/of97-724/methods.html
2) On Mt Etna, Sicily, the use of huge concrete blocks dropped from helicopters to divert the flows.Dave
I ran across the following about a week ago.
Jan-Feb 1960 Kilauea eruption, at about the same location as the current activity:
@ 08:00: "Bulldozers are called to work..."
CSAV Hawaii: 1960 Eruption of Kapoho
LongVideosCSAV [Center for the Study of Active Volcanoes]
Published on Jan 10, 2011
@ 09:46 "...every bulldozer in the area is mobilized to build the highest dike yet attempted."
The video is interesting in that it wasn't publicly available until 2011.
ref: Fred Rackle, born in 1920, moved to Honolulu in 1938 as an Army Corps photographer.
A few days ago, I noted that the anniversary of the Mt. Saint Helens' 1980 eruption was coming up, which is today, so I did some "independent" research. :redface:
Three diagrams of Earth, Moon and Sun positions on a starry background: March 27, 1964 Alaska earthquake, March 16, 1980 Mt St Helens start of seismic activity, and May 1, 2018 Kilauea start of seismic activity.
Fortunately, the USGS came to the same conclusion, as far as I can tell:
But, as anyone with half a brain knows, there is an alignment of the earth, moon, and sun every two weeks.
And there are not "world altering" earthquakes every two weeks. :oldeyes:
I should probably clarify something I said earlier;
OmCheeto said:
Mount St. Helens is only 50 miles from my house, and I stay the hell away from it.
At the ripe old age of 21, I got about as close as I could get to St. Helens. A place called:
Ape Cave
Ape Cave is a lava tube located ... just to the south of Mount St. Helens in Washington state. Its passageway is the longest continuous lava tube in the continental United States ... Lava tubes are an unusual formation in this region, as volcanoes of the Cascade Range are mostly stratovolcanos and do not typically erupt with pahoehoe (fluid basalt).​
  • Three diagrams of Earth, Moon and Sun positions on a starry background: March 27, 1964 Alaska earthquake, March 16, 1980 Mt St Helens start of seismic activity, and May 1, 2018 Kilauea start of seismic activity.
live streaming … NOW
new live stream video
for this current live stream, it is now night time over there and the activity as appeared to seriously increased since this morning
make sure you turn the sound up to hear the lava and gasses venting
Here is a great video that a friend just sent me.
https://player.vimeo.com/video/270773299
Ape Cave
IN
India
During the summer of '81 I was taking flying lessons out of Kelso , WA. They were making sightseeing tours by plane over the mountain. One of my solo flights was to Yakima, WA , which took me right past St. Helens, so I got to view the crater and devastation from the air.
One of the things I've decided I've never liked about the videos from Hawaiian volcanoes, was the lack of vertical perspective.
Another thing, was that they all seemed to be in slow motion.
So yesterday, I put my mind in gear.
The videos are not in slow motion. They just appear that way, due to telephoto lenses.
Here are the results of my efforts:
Screenshot of a lava fountain video frame annotated with measurements: a 105 feet height arrow, a 36 feet arrow, apex and eruption base markers, and the note 6 seconds times 1/4 speed = 1.5 seconds with d = at^2/2.
Yesterday, I counted the seconds from apex to ground for a different spot, as being 4 seconds long, which, from the equation, meant the lava was flying 256 feet in the air.
Which is over twice the height of my 100 foot tall trees in my back yard.
And that, impressed me.
Anyways, if anyone should watch future videos, count the seconds from apex to ground, and use the following chart, for how high the FREAKIN' LAVA is shooting into the air:
Code:
sec   feet
 1      16
 2      64
 3     144
 4     256
 5     400
 6     576
 7     784
 8    1024
 9    1296
10    1600
11    1936
  • Screenshot of a lava fountain video frame annotated with measurements: a 105 feet height arrow, a 36 feet arrow, apex and eruption base markers, and the note 6 seconds times 1/4 speed = 1.5 seconds with d = at^2/2.
Fewmet said:
An overview of the geologic setting that I found useful.
They pointed out another impressive number that I glossed over and completely ignored:
@3:05; "...when the south side moved 2 meters to the south."​
I actually didn't believe it, so I did some research and found:
Hawai‘i Volcano Watch: Slow Slip on Kīlauea’s South Flank Expected this Year
By USGS Hawaiian Volcano Observatory
February 23, 2018, 12:22 PM HST
Today’s Volcano Watch begins with a question: Can you guess when the next slow slip event will happen on Kīlauea Volcano’s South Flank? As a hint, the last one was in October 2015, and before then, events occurred in May 2012, February 2010 and June 2007. If this seems like a pattern, you’re right.
What is a “slow slip event” anyway?
Slow slip events are sometimes called “slow earthquakes” or “episodic slip events.” They happen when a fault begins sliding, just like in a regular earthquake, but so slowly that it takes several days to finish instead of several seconds.
However, slow earthquakes produce no seismic waves and, therefore, none of the damaging shaking of a regular earthquake.
I think this kind of answers @berkeman 's thread question a bit more to my liking: Magnitude 6.9 Earthquake in Hawaii versus on the Hayward Fault -- What am I missing?
I guess I now have to figure out what "seismic wave" and "earthquake" actually mean.:confused:
ps. It looks like they nailed their prediction;
Because the most recent slow slip event on Kīlauea happened in October 2015, and the events have a recurrence time of 2.5 years (give or take three months), we can forecast that the next one might occur between now [Feb 23, 2018] and August 2018. But remember, there won’t be any shaking or other effect that could be easily felt by individuals.​
Feb, Mar, Apr, May, Jun, Jul, Aug
Scientists are kinda smart. :biggrin:
Men, on the other hand, as I pointed out earlier...
Hawaii volcano: Man hit by lava in first serious Kilauea injury [BBC :rolleyes:]
The first serious injury has been reported as Hawaii continues to grapple with weeks of volcanic eruptions and lava flow.
The injured man was sitting on a balcony at his home when "lava spatter" - projectile molten rock - landed on him.
"It hit him on the shin and shattered everything there down on his leg," a spokeswoman for the county mayor said.
Lava spatters can weigh "as much a refrigerator", she told Reuters.
Guessing this "spatter" was not the size of a refrigerator, and the man, is an idiot, who didn't evacuate.
Thank god for women's lib.
Composite of three zoomed photos of people on dark, rough lava rock with grass and a palm tree; a magenta arrow labelled "Yay! Woman standing on lava" points to a figure in a red top; red lines mark the lava edge.
  • Composite of three zoomed photos of people on dark, rough lava rock with grass and a palm tree; a magenta arrow labelled "Yay! Woman standing on lava" points to a figure in a red top; red lines mark the lava edge.
