Heat and max temperature Problem
The discussion addresses the misconception that a temperature of 28°C is twice as hot as 14°C. The participant utilizes the equations Q=mcΔT and Q=ml to analyze heat absorption in a 1kg aluminum block at both temperatures. Through calculations, they determine that 28°C is approximately 5% hotter than 14°C when converted to Kelvin, revealing that Celsius is not an absolute temperature scale. The conclusion emphasizes that a temperature of 301°C (or 2 times 287K) would be considered twice as hot as 14°C.
  • Understanding of thermodynamics concepts, specifically heat transfer.
  • Familiarity with the equations Q=mcΔT and Q=ml.
  • Knowledge of temperature scales, particularly Celsius and Kelvin.
  • Basic algebra for manipulating equations and performing calculations.
  • Research the principles of thermodynamics and heat transfer.
  • Learn about the differences between Celsius and Kelvin temperature scales.
  • Explore the concept of absolute temperature and its significance in thermodynamics.
  • Study practical applications of Q=mcΔT in real-world scenarios.
Students studying physics, educators teaching thermodynamics, and anyone interested in understanding temperature scales and heat transfer principles.
someone1029
[SOLVED] Heat Problem
The question is:
If today's maximum temperature was 14°C and tomorrow's maximum is expected to be 28°C, will tomorrow be twice as hot as today. Explain your answer.
The only equations known are Q=mcΔT, and Q=ml
Where Q= energy in joules. m=mass in kg, c= specific heat capacity [to 3 decimal places], ΔT= the change in temperature in either kelvin or Celsius, l= latent heat [also to 3 decimal places]
However I am not limited to these equations, just expected to use them. Use of other equations is fine, so long as they are within reason.
My train of thought was that, I need to find out and compare how many watts of heat will be absorbed by an identical body of mass over the same period of time at the two different temperatures, i just don't know how. I also think that this is one of those questions designed to trick, or at least make you really think. So I think that the short answer to the question is no, I just can't prove this right or wrong.
I have tried taking a theoretical 1kg aluminium block and putting them into each of the temperatures resulting in these equations:
8.90e+3*14=124600
8.90e+3*28=249200
as 249200 is 2*124600 then it is twice as hot
However I do not think this is right as these values are the amount of energy required to make this temperature change. Am I on the right track, or am I nowhere near the answer?
Think about this: is zero degress C the bottom of the celsius temperature scale?
No it isn't, -273°c is. Can you please explain the relevance of this though? I just chose 0°c as a point from which the blocks would get heated. If you convert the temperatures to kelvin you get exactly the same results.
14\circC is 14 + 273 = 287 degrees above absolute zero. 28\circC is 28 + 273 = 301 degrees above absolute zero.
Now \frac{301}{287} = about 1.05, and so 28\circC is about 5% hotter than 14\circ, not twice at hot.
A temperature of 2(287) - 273 = 301\circC is twice as hot as 14\circC.
The celsius scale is not an absolute T scale. The kelvin scale is. 0K is absobute zero and so, for example, 300K is twice as hot as 150K.
Ok, I was just trying to over complicate things, as usual. Now that I look back at the problem I see how simple it is. Thanks for your help, no doubt I will call on it again some time in the future.
  • · Replies 33 ·
