Heat change between system and surrounding
The discussion revolves around the concept of reversible heat transfer between a system and its surroundings, exploring the conditions necessary for such reversibility, particularly in the context of thermodynamic principles and entropy. Participants examine theoretical scenarios, equations, and examples related to heat change, entropy, and phase transitions.
  • One participant suggests that for a reversible heat change, the work done (w') must be maximized, implying that a large amount of heat change is necessary for reversibility.
  • Another participant introduces the example of melting/freezing as a reversible process, noting the associated entropy change during phase transitions.
  • A participant expresses confusion regarding how the previous explanation relates to their question about equating heat transfer between the system and surroundings.
  • There is a discussion about the conditions under which dQ (heat transfer) and dU (internal energy change) can be small, and how this affects the reversibility of the process.
  • Participants question how to achieve an infinitesimal temperature difference necessary for reversible heat transfer when starting from a finite temperature difference.
  • One participant suggests that theoretical approaches can simplify understanding, while real-world examples may also aid comprehension, referencing previous discussions on the forum.
  • A later reply elaborates on the example of latent heat, explaining that heat exchange occurs at constant temperature during phase changes, which aligns with the requirements for reversibility.
Participants express varying levels of understanding and agreement on the conditions for reversible heat transfer. Some agree on the necessity of infinitesimal temperature differences, while others raise questions about practical scenarios and the implications of finite temperature differences. The discussion remains unresolved with multiple competing views on the topic.
Participants highlight limitations regarding the assumptions made about temperature differences and the definitions of terms like dQ and dU. The discussion also reflects a dependency on specific examples, such as latent heat, to illustrate theoretical concepts.
This discussion may be of interest to students and professionals in thermodynamics, physics, and engineering, particularly those exploring concepts of heat transfer, entropy, and phase transitions.
weng cheong
how can heat change between system and surrounding be reversible?
du=q-w'
in this case, heat change, i reckon
a)since u is state function, there is no change in U, thus change in u is 0
b) 0=q-w' hence q=w' , all the heat transferred is spent on doing work
c) in order to make this reversible, w' must be maximum, so does the q1)does it mean that if i would like to get a reversible change, the amount of heat change between system and surrounding must be huge enough?
a small amount of heat change will be irreversible?
2) i found that in order to have a infinitesimal steps in the exchange of heat, temperature difference of the system and the corresponding surrounding has to be infinitesimal.
what if the amount of q is huge enough to make a difference in the temperature of system?
Chemistry news on Phys.org
Good morning weng cheong.
Probably the simplest example of a reversible heat change is melting / freezing with the exchange of latent heat of fusion.
There is also a substantial entropy change associated with this phase transition.
go well
i'm sorry, i don't get it. how does your explanation answer my question? can you explain in more detail?
actually I'm studying entropy. i came across the equation: dSsurr = -Qsys/Tsys.
Thus, i need to understand how can the heat transfer between system and surrounding be reversible that we can equate the Qsurr to Qsys.
Andrew Mason,
thanks for clearing my doubt, i wish to continue the discussion here.
1) dQ = dU - dW'
i agree that to enable the reversibility, W' has to be maximum.
is there any restriction to the values of dQ and dU?
what if the dQ is too small to cause a difference in T, then dU=0, dQ=dW'? when dW' is max,
dQ is maximum too?2) for a reversible transfer of heat, we need infinitesimal temperature difference between the system and surrounding to facilitate the infinitesimal transfer of heat.
However, how do we achieve this? does it has something to do with the fact that the surrounding is very large compared to the system?
What don't you get?
Studiot,
or would you please answer my another question?
for reversible heat transfer heat transfer, infinitesimal temperature difference is required.
when the system and surrounding are at the same temperature, there will be no problem. what if at the beginning of process the system and the surrounding are at different temperature(finite temperature difference)? how can infinitesimal temperature difference be achieved?
Sometimes being highly theoretical about a subject simplifies things and helps towards understanding, sometimes working through real world examples helps.
I suggest a few examples here.
Your question has appeared many times on PF here was a previous answer. I am sorry that the forum Tex change has messed up the formatting.
https://www.physicsforums.com/showthread.php?t=467891&highlight=entropy+fusion
Latent heat is a good example and fusion is better than vapourisation since the volume/pressure change is so small we can neglect any work done.
Heat is exchanged between a pure substance and its surroundings on melting or solidifying.
However to strictly conform to the infinitesimal temperature difference/equilibrium requirement we should draw our system boundary between the liquid and solid phases of the pure substance. tthe solid is the system and the liquid the environment.
We know that for a pure substance the cooling curve halts at the melting/freezing point until all the solid is transformed to liquid.
So both solid and liquid are at the same temperature and heat transfers between them conform to the strict requirements for reversibility.
No work is done
All this heat equals the change in internal energy
Since the melting occurs at constant temperature the entropy change equals the heat exchanged divided by the melting temperature
The process is reversible
Yes the liquid receives its heat from the rest of the universe under slightly different conditions, but it is often convenient to ignore this.
does this help?
  • · Replies 22 ·
