Heat Dissipation in Resistors: Does Direction Matter?
4 replies · 2K views
sArGe99
Does the heat dissipated in a resistor necessarily depend on the direction of current through it? As far as I know the heat dissipated equals square of the magnitude of current thru resistor multiplied the resistance of the resistor. But it seems direction matters.
Why do you think direction matters? Can you give an example?
Squaring the current makes the direction irrelevant. Are you imagining a case where it would matter?
Peltier effect, Thomson effect. There's both Peltier heating and Peltier cooling depending on the direction of current.
You won't find such effects with an ordinary resistor. You need a semiconductor or a junction of dissimilar metals.
