Heat Equation With Seperable Variables
3 replies · 2K views
Rweir
du/dt = d2u/dx2 + u
Bc: u'(0) = u'(1) = 0
Ic: u(x,0) = 1
Using sturm-liouville to solve for eigenvalues.
After first separating variables in the equation
we get G'/G - 1 = F'' = λ
after using Sturm-Liouville we find that
F(x) = Acos(n*Pi*x)
G(t) = Ae(-n2pi2-1)t
So after multiplying them together and then taking the initial condition of u(x,0) = 1
we get A*cos(n*pi*x) = 1 and thus the problem arises after using Fourier expansion we get A = 0 which makes everything 0. Any suggestions as to why it is coming out like this?
first the u makes it a little different, its not your standard heat conduction equation, so you have
u_t = u_xx + u
so i get to
X'' + (λ-1)X = 0
T' + λT = 0
so you won't be able to satisfy the BCs for (λ-1)<0
now how about when λ = 1?
have a think about the normal heat equation
u_t = u_xx
the rate of change with time of temp is proportional to the spatial curvature of the temp, ie everything gets smoothed out...
u_t = u_xx + u
now the rate of change also has a component proportional to temp as well...
and note the IC is initially uniform everywhere
now think about your BCs
u'(0) = u'(1) = 0
which in the normal heat equation are equivalent to insulated ends
but also stepping back a bit, as the basis functions are orthogonal, shouldn't the coefficient in the sum be proportional to
[tex]a_n = \int dx.cos(n \pi x ) .u(x,0) = \int dx.cos(n \pi x ) .u(x,0)[/tex]
which is different from every basis function having to satisfy the IC, only their sum has to
