Heat from inside the Earth causing global warming?
In summary: Scientists have extensively measured the flow of heat from inside the earth- it amounts to about 0.075 Watts per square metre, while incoming solar radiation is 342 Watts per square metre, about 5000 times as much. Hissink is correct that heat from the Earth is not included in climate models- but that is because it is negligible. The heat from inside the Earth is generally thought to be a relic of its formation and not of fast-breeder type nuclear reactions.
verdigris
119
Could heat from inside the Earth be causing global warming? If more heat was rising from the ocean floors would we notice - particularly if it was only happening in a few small areas?
According to accepted theory, no.
Earth receives "all" the energy from sun. Earth is assumed to emitt all the radiation it receives (to form equilibrium) but some of this emitted energy gets trapped and re-radiated back to the surface by certain gasses (H2O, CH4, CO2, ...), which causes warming of the troposphere and makes life possible. Otherwise, the Earth would be on average about 40 deg cooler than it is now.
How do we know the heat isn't coming from inside the Earth?
Does the earth’s interior make an overwhelming contribution to the surface temperature?
This claim seems to be contradicted by the fact that it is warmer in daytime. And in summer. And closer to the equator. It takes a rare kind of talent to present an argument on climate change that is inconsistent with the existence of seasons.
Scientists have extensively measured the flow of heat from inside the earth—it amounts to 0.075 Watts per square metre, while incoming solar radiation is 342 Watts per square metre, about 5000 times as much. Hissink is correct that heat from the Earth is not included in climate models—but that is because it is negligible.
"Scientists have extensively measured the flow of heat from inside the earth"
Where did the scientists measure the flow of heat from inside the Earth?
Heat could be coming from places that have not been surveyed.
http://geophysics.ou.edu/geomechanics/notes/heatflow/global_heat_flow.htm"
That's a great web link.It would be interesting to know if the 24000 heat flow measurements have been made in the same places over a period of years
to map any variability.Also the heat measurements on the sea relied on correction for hydrothermal loss and this would depend on hydrothermal loss models being accurate.I agree now that the heat contribution from the Earth's interior is insignificant.
The heat from the interior is isignificant to global warming, but it makes the Earth dynamic, without interior heat sources from the decay of radioactive nuclei we would'nt have plate tectonics and there wouldn't be any volcanoes or (at least much less) earthquakes
Edit: I just clicked on that link and it said pretty much what i said, although I wouldn't trust that link entirely seeing as nuclear fission is a process which absorbs energy!
Perhaps there is a lot more to it, that internal heat. Plenty more.
Billiards said:
"Edit: I just clicked on that link and it said pretty much what i said, although I wouldn't trust that link entirely seeing as nuclear fission is a process which absorbs energy!
In any case,the heat from inside the Earth is generally thought to be a relic of its formation and not of fast-breeder type nuclear reactions as I read on Wikipedia.
1. How does heat from inside the Earth contribute to global warming?
The Earth's core is made up of molten iron and nickel, which produces significant amounts of heat. This heat is transferred to the Earth's surface through convection, and contributes to the overall temperature of the planet. As the Earth's core continues to generate heat, it adds to the overall temperature of the planet, contributing to global warming.
2. Is the heat from inside the Earth a significant factor in global warming?
While the heat from the Earth's core may not be the main cause of global warming, it is still a significant factor. It is estimated that the heat from the Earth's core contributes about 0.03% to the overall temperature of the planet. While this may seem small, it is still a measurable and important contribution to global warming.
3. Can the heat from inside the Earth be controlled to slow down global warming?
The heat from the Earth's core is a natural process that cannot be controlled by humans. While we can take steps to reduce our own carbon emissions and slow down global warming, we cannot directly control the heat generated from within the Earth.
4. How does heat from inside the Earth compare to other sources of global warming?
The main source of global warming is the increase in greenhouse gases, such as carbon dioxide, in the Earth's atmosphere. This is primarily caused by human activities such as burning fossil fuels. While the heat from the Earth's core does contribute to global warming, it is not as significant as these other sources.
5. Can the heat from inside the Earth eventually lead to catastrophic global warming?
There is no evidence to suggest that the heat from the Earth's core will lead to catastrophic global warming. While it does contribute to the overall temperature of the planet, it is not a significant enough factor to cause catastrophic warming on its own. It is important to focus on reducing our carbon emissions in order to mitigate the effects of global warming.
  • Earth Sciences
  • Earth Sciences
