Why Is the Total Area for Calculating Heat Loss 320 Square Feet?
The total area for calculating heat loss in a 10 ft by 10 ft room with an 8 ft ceiling is 320 square feet, which includes all four walls. The formula used is heat loss = Q/t = (Area × (T1-T2))/R, where T1 is the inside temperature (68°F) and T2 is the outside temperature (28°F), and R is the insulation value (R19). Each wall contributes to the total area, leading to the calculation of 320 ft², not just the floor area of 80 ft².
  • Understanding of heat transfer principles
  • Familiarity with insulation ratings, specifically R-values
  • Basic knowledge of temperature difference calculations
  • Proficiency in using the heat loss formula
  • Study the concept of R-value and its impact on energy efficiency
  • Learn about heat loss calculations in different room configurations
  • Explore the implications of temperature differentials on heating systems
  • Investigate insulation materials and their effectiveness in various climates
Students studying thermodynamics, HVAC professionals, and anyone involved in energy efficiency assessments for residential buildings.
tweety1234
Calculate wall loss rate in BTUs per hour. For a 10 ft by 10 ft room with an 8 ft ceiling, with all surfaces insulated to R19 as recommended by the U.S. Department of Energy, with inside temperature 68°F and outside temperature 28°F:
heat loss = \frac{Q}{t} = \frac{(Area) \times (T1-T2)}{R}
I don't get the working out,
can someone please explain why the area is 320ft^{2}?
\frac{Q}{t} = \frac{(320 ft^{2}) \times (68-28)}{19} surely its just 10 x 8 = 80 ft?
How many walls are there in a square room?
4? But how does that make 320?
Dont worry, I got it,
thanks for your help.
