Heat pumps and shape-memory alloys motor
This discussion centers on the feasibility of generating electricity using a heat pump in conjunction with a shape-memory alloys motor. Participants clarify that while a heat pump can provide a coefficient of performance (COP) of 3-5, the efficiency of converting thermal energy back into mechanical energy through a shape-memory engine is highly dependent on the temperature differential. The consensus is that using a heat pump to drive a shape-memory engine for electricity generation is inefficient and does not approach the concept of perpetual motion. The efficiency of a Stirling engine, which is often compared, varies based on the thermal energy source and sink, and is not fixed at 30% as commonly assumed.
  • Understanding of heat pump technology and its coefficient of performance (COP)
  • Knowledge of Stirling engine mechanics and efficiency calculations
  • Familiarity with shape-memory alloys and their applications in energy conversion
  • Basic principles of thermodynamics, particularly the Carnot cycle
  • Research the efficiency of Stirling engines under varying temperature differentials
  • Explore the applications of shape-memory alloys in energy systems
  • Investigate the thermodynamic principles governing heat pumps and their performance metrics
  • Examine alternative energy generation methods that utilize thermal energy more effectively
Engineers, researchers, and students interested in thermodynamics, energy conversion technologies, and the practical applications of shape-memory alloys in energy systems will benefit from this discussion.
magi
Heat pumps and shape-memory alloys motor...
Hi.
Would it be possible to get some electricity from a heat pump and shape-memory alloys motor/engins with a generator?
A heat pump use 1 kW and give you 3-5 kW heat.
Would it be possible to use shape-memory alloys motor and a generator to generate some electricity.
Or is the efficiency too low?
http://www.smaterial.com/SMA/engine/engine.html
Or what about a solar parabol.
The efficiency of electric solar panels is at the most 20%.
Can you get more efficiency when using a shape-memory alloys motor?
Regards Magi
The proposed motor seems to be a variation on a Sterling engine, or a K-cycle with NiTiNOL replacing the pistons. It's certainly workable, but I don't know what the efficiency would be compared to a regular Sterling.
magi said:
Hi. Would it be possible to get some electricity from a heat pump and shape-memory alloys motor/engins with a generator? A heat pump use 1 kW and give you 3-5 kW heat.
Are you talking about a perpetual motion device? Getting electricity out with no electricity input? Are you saying you would have a heat pump driven by a shape memory engine in a closed loop, but in which case the shape memory engine produces more mechanical energy than is required by the heat pump?
I hope that's not what he meant! It's possible, I guess, but I assumed that he meant that the thing produced 3-5kW from an input of 4-6kW (1kW wastage).
Not a perpetual motion device.
I were just asked if shape-memory alloys could be used in any way.
I'm just wondering why you are considering using the thermal energy from a heat pump? What's the point of using electricity to generate some thermal energy? That's the part that had me confused. Some shape memory engines could run off the small temerpature differential of a heat pump, but what's the point of doing so?
Ben Wiens said:
I'm just wondering why you are considering using the thermal energy from a heat pump? What's the point of using electricity to generate some thermal energy? ?
Agreed. There is no point and it is not engineerably sensible to convert electricity into heat and then electricity again. The conversion of heat into any form of mechanical energy (and electricity is an energy with an extraordinary internal available amount of mechanical energy) is very inefficient.
A guy just asked me a simpel question once.
-I take 1 kW and feed it into a heat engine and get heat out of it around 3-4 kW. Why can't I transform the heat to energy to get a perpetual motion device.
I know about the carnot cycle.
Then a guy asked what is possible to do with shape-memory alloys.
A sterling engine has a efficiency around 30 % and a electric solar panel have 20- 30 % so what efficiency have a shape-memory alloys engine.
And I just wanted to see what people said about this... :)
It sounds like you're still fuzzy about the issue. A Stirling or any other engine does not have a definite efficiency such as 30%. It totally depends on the temperature differential between thermal energy source and thermal energy sink. So if the Stirling engine is receiving thermal energy from a heat pump with a coefficient of performance of 5, then the heat engine will have an efficiency of no greater than 20% or 1/5th. If the Stirling engine is receiving thermal energy from a heat pump with a coefficient of performance of 10, then the heat engine will have an efficiency of no greater than 10% or 1/10th.
Heat Pump COP and perpetual motion machine
I'm a little fuzzy on the efficiency calculations. Wouldn't a heat pump with a COP of 5 put out five times the energy it requires to run? In that case it could be coupled to a Sterling engine with, say 25% efficiency for a net efficiency of 125% (enough for "perpetual motion"). The heat pump could be run by the shaft output of the Sterling, avoiding electircal conversion losses.
Ben is correct.
Real heat pumps don't have efficiencies anywhere near that high, but the reall killer is that while the Stirling engine's efficiency is directly proportional to temperature difference, the heat pump's efficiency is inversely proportional to temperature difference. So the higher you get the heat pump in efficiency, the lower the Stirling engine gets. And vice versa.
Just look at the equations for http://en.wikipedia.org/wiki/Carnot_heat_engine" (Equation 3 - same as Stirling Engine
and
http://en.wikipedia.org/wiki/Coefficient_of_performance"
Notice the terms are the same (Tc, Th).
You can always get your heat from another source (ie, the sun), but then that isn't perpetual motion either.
  • · Replies 19 ·
  • · Replies 17 ·
