Heat transfer: All 3 modes together
3 replies · 3K views
chetanladha
Hi.
How can i find out the temperature rise in a steel plate of known dimensions, when exposed to sunlight, losing heat to air flowing over it by convection, and heat getting transferred to another body by convection?
I hope to hear about the different approaches that could be taken.
Thanks in advance.
Basically, you will perform an energy balance from radiation absorbed from the sun, radiant energy emitted from the plate, and convection energy loss as follows:
Energy absorbed by sun (Es) = absorptivity X solar radiation power density
For a steel plate, you can use absorptivity = 0.5. A good average value of energy from the sun at the surface of the Earth is 750 watt / m^2.
Now the plate will "re-radiate" energy back into space as follows
Er = emmissivity * Stefan Boltzmann constant X surface area of plate (plate surface temperature ^ 4 - sky temperature ^ 4)
you can use emmissivity = 0.21 for your steel plate and sky temperature (not ambient temperature) = - 5 C. Make sure your temperatures are in Kelvin and Rankine.
Finally, use Newton's law of cooling for the convection:
Econv = A * h * (T-surface - T-ambient)
And you can find h from a vertical plate natural convection correlation.
The solution is trial-and-error. Assume a value of T-surface until:
Es = Er + Econv
Many Thanks for your response.
Can u please explain why have u used sky temperature radiated energy, and not the ambient temperature.
Also, is it appropriate to use sky temperature as -5, or should it be 3 Kelvin?
Atmospheric emmision is often estimated as blackbody, hence the "sky" temperature. You want to use an average temperature for the atmosphere so 3 K is too low (would suggest - 5C to -10C).
