Understanding the Difference Between Heat and Thermal Energy
The discussion revolves around the definitions and distinctions between heat and thermal energy, exploring their meanings within the context of thermodynamics. Participants examine the implications of these terms in both theoretical and practical applications, raising questions about consensus in the scientific community.
  • Some participants propose that thermal energy is the kinetic energy of the random motion of particles, while heat is defined as the transfer of energy between bodies not in thermal equilibrium.
  • Others argue that thermal energy and heat may be considered the same, associated with the kinetic energy of particles, but not necessarily linked to energy transfer.
  • A participant notes that there is general agreement that ΔQ represents "heat flow," but the term "heat" can be ambiguous and historically rooted in misconceptions.
  • One participant emphasizes that ΔQ refers to energy transfer during a thermodynamic process, while internal energy (ΔU) is the only quantity representing energy contained by a body.
  • Another participant seeks clarification on whether thermal energy is synonymous with heat and questions the nature of energy transfer when a bullet stops suddenly.
  • A later reply describes thermal energy as a form of internal energy related to the kinetic energy of molecules in thermal equilibrium and explains that stopping a bullet involves work done on the wood, increasing its internal energy.
Participants express differing views on the definitions and implications of heat and thermal energy, indicating that no consensus exists on these terms within the scientific community.
Participants highlight the historical context of the term "heat" and its varying interpretations, which may contribute to the confusion surrounding its definition. The discussion also reflects on the limitations of terminology in conveying precise scientific concepts.
hushai1
There seems to be considerable confusion in the scientific community about thermal energy and heat. I have read several textbooks on thermodynamics and several posts in scientific forums and they certainly don't agree on what is heat and thermal energy. For some: thermal energy is the kinetic energy of the random motion of particles and heat is a transfer of energy between two body that are not in thermal equilibrium. For some thermal energy and heat are the same thing but they are a form of energy associated with the kinetic energy of the random motion of particles and not necessarily associated with transfer.
My questions are these:
Is there an actual agreement in the scientific community about these terms?
If there is, what is the most precise definition given to these terms? What is the mathematics behind it?
If there is not, what would be the most authoritative source that could be used to define them?
Do you know of any book that explain this thoroughly using even advanced mathematics and physics?
Thank you
Science news on Phys.org
Thank you
There is general agreement that \Delta Q is "heat flow". But, apart from that, "heat" is a loose term that can be used to refer to different things. The confusing use of the term "heat" may be historical. Heat was originally thought to be some kind of substance that flowed between bodies.
"Heat flow" is embodied in the first law of thermodynamics:
\Delta Q = \Delta U + W
When applying the first law to a thermodynamic process involving a system, \Delta Q is the heat that flows into the system during the process, \Delta U is the change in internal energy of the system, and W is the work done by the system. If the heat flow is into the system, \Delta Q is positive. If the heat flow is out of the system, \Delta Q is negative. Sometimes scientists use the term "heat" to mean \Delta Q.
"Heat" is often used in a different context - as something that a body contains - ie. the quantity of "heat" contained by a body. This is not a good idea to use heat in this way because it causes confusion with \Delta Q.
\Delta Q does not refer to anything "contained" by a body. It refers to energy transfer to or from the system during a process. W - work - does not refer to anything contained by a body either. W refers to the mechanical work that is performed by the system during a process. In the first law, the only quantity that represents to something contained by a body is \Delta U - the internal energy of the system.
AM
Thank you very much for your answer.
It seems clear to me now that heat is energy in transfer. What is thermal energy? Is it the same as heat? If a bullet is stopped suddenly, what energy transfer is taking place since it cannot be heat?
Regards,
Regards,
Thermal energy a form of internal energy. It is the energy due to the kinetic energy of the molecules in a substance which is in thermal equilibrium (ie in which the molecular kinetic energies follow a Maxwell-Boltzmann distribution).
A bullet stopping in a piece of wood is an example of Work: a force being applied through a distance. In that case, the work being done on the wood increases its internal energy. Since dQ = 0, dU = dW (first law of thermodynamics).
AM
  • · Replies 16 ·
14K
