Heating a block of Rubber by passing electricity
The discussion focuses on heating an aluminum block (5" x 5" x 1") to 10 degrees Celsius by embedding copper strips or wires and passing 120V at 2.5 Amps through them. Participants recommend using nichrome wire instead of copper due to its better resistive heating properties. The challenges of using rubber as an insulator are highlighted, as it may lead to uneven heating and hotspots. Suggestions include exploring conductive rubber or laminating sheets of plastic with fine metal mesh for more uniform heat distribution.
  • Understanding of electrical resistance and heating elements
  • Familiarity with nichrome wire and its properties
  • Knowledge of thermal conductivity in materials
  • Basic principles of heat transfer and insulation
  • Research the properties and applications of nichrome wire for heating
  • Explore calculators for resistive heating and temperature rise
  • Investigate conductive rubber and its manufacturing processes
  • Study heat distribution techniques in thermal insulation materials
Engineers, materials scientists, and hobbyists interested in electrical heating methods, thermal management, and material properties for effective heat distribution.
sakthi
Hi everyone.
I want to heat a piece of Rubber by embedding copper strips or wires in it and passing electricity(120V - 2.5Amp) through it. The room temperature is 0(zero) deg Celsius and i want to heat the aluminum block(5" x 5" x 1") to 10 deg Celsius(Not more than 10 deg).
Question: How will I determine the size of the copper strips or wires that I have to use to generate enough heat to raise the temperature of the block to 10 dec C.
THANK YOU FOR YOUR SUGGESTION.
sakthi said:
Hi everyone.
Welcome to the PF.
You should probably use nichrome wire instead of copper. There is a calculator in post #2 of this thread that should help you:
https://www.physicsforums.com/showthread.php?t=463274
I wouldn't recommend this method for heating a block of rubber.
Rubber itself is a thermal insulator so embedding resistive wires into the block is likely to lead to hotspots around the wires, without raising the block temperature evenly.
Conductive rubber can be made by incorporating carbon granules in the rubber matrix. Using this method will ensure even resistive heating.
Thank you berkeman.
I will try the calculator.
Studiot - Thank you for your suggestion.
So, I cannot use rubber at all.
Can I use some kind of thermoplastic. What is your take on that.
Plastics materials, natural or artificial = thermal insulator so the same comment applies.
A lamination of sheets of plastics with sheets of very very fine metal mesh might heat evenly enough.
You need to distribute the heat as widely as possible.
The problem to overcome is that the rate of heat transference away from the heating element must not be less than the rate of heat production in the element.
berkeman - The calculator holds good only for higher temperature(80 dec C onwards). I am looking something really small (10 deg C). Is there an equation to find out the size of the copper strips that will induce the heat.
Thank you
14K
