Heating up water- energy required
The discussion revolves around the calculation of energy required to heat water and the design of a waste heat recovery system for an air conditioning unit. It includes both theoretical calculations and practical applications related to energy transfer and system design.
  • Technical explanation, Experimental/applied, Homework-related
  • One participant presents a calculation for the energy required to heat 7,500 kg of water using 4 kW of electrical power over 20 hours, arriving at a delta T of 9.14 °C.
  • Several participants confirm the correctness of the initial calculation.
  • Another participant poses a question regarding the design of a waste heat recovery system to utilize heat from an air-cooled condenser of a 4-ton air conditioning unit for heating water.
  • A request for resources or information on designing heat recovery systems is made by a participant.
Participants generally agree on the correctness of the initial energy calculation. However, the discussion about the design of the waste heat recovery system remains unresolved, with no consensus on specific design approaches or resources.
The discussion does not address specific assumptions related to the efficiency of the heat recovery system or the exact requirements for the hot water needed for bathing purposes.
Individuals interested in energy calculations, heat recovery systems, and practical applications in HVAC systems may find this discussion relevant.
vikmak
Is the below calc right?
Input electrical power for heating- 4KW
Heating time= 20 hrs = 72,000 sec
Input energy available= = 288,000,000 J
Qty of water to be heated- 7,500Kg
Specific heat of water- 4,200 joules/Kg/deg C
Delta T in Celsius that can be achieved with the said input energy is 9.14 ?
yes!
grzz said:
yes!
Thanks!
Now the bigger question. How do you design a waste heat recovery system to heat water from the heat out of air cooled condenser of a 4 ton air conditioning unit. This 4 ton air conditioning unit runs for 24 hrs. Hot water is required for bathing purposes in a hostel.
can anybody tell me where to look in for information on design related to heat recovery system?
  • · Replies 67 ·
  • · Replies 40 ·
  • · Replies 30 ·
