Derek P
- 297
- 43
Spun off from https://www.physicsforums.com/threads/is-quantum-physics-retro-deterministic.945431/#post-5984157.
@Gerinski said:
if we measure a particle's position at time X (not caring about its momentum) and we measure it again at a later time Y and we find it at some other position (again not caring about its momentum), do those 2 position measurements not enable us to infer what its position and momentum must have been between time X to Y?
@A. Neumaier said:
Yes, this is indeed more or less the way momentum is inferred from particle tracks. But the measured positions are uncertain, which implies a much bigger uncertainty in the resulting momentum. There is no way to escape the Heisenberg uncertainty relation.
I said:
It depends on the experimental arrangement but it is not difficult to use a shutter to fix the position and time with arbitrary precision at both measurements.
@A. Neumaier said:
You cannot construct a shutter with sharp enough borders to guarantee this - at some point the molecular structure of the shutter gets in the way.
My argument does not depend on being able to push the experimental accuracy to arbitrary limits. The point is that experimental limitations are not the same as quantum uncertainty and may usually be reduced to many orders of magnitude less than the latter. To put it simply, the uncertainty in the measurement of momentum does not derive from errors or even the uncertainty of the two positional measurements.
Experimentally, a one-dimensional system is harder to use than a two dimensional one a) because the particles have to have a large drift velocity on top of the momentum and b) slicing a moving beam is likely to be much less precise than using a static slit or pinhole, c) in two dimensions the deflection momentum is translated to an angle so the system resolves the measurement to position on a screen. But no matter, the timing method was, after all, a gendankenexperiment.
So to a feasible experiment with back-of-the envelope numbers.
Consider a field emission cathode and a polished dynode detector. The drift potential is 1 v, the drift distance is 10 m and the temperature is 0.1 Kelvin. The cathode is pulsed with a 70ps pulse and the resolution of the detector is the same.
Absolute accuracy is not relevant, it is repeatability that matters here. I'll use the term "error" here for the uncontrollable random variations.
Call the time error 100 ps.
Drift velocity is v = 600,000 m/s.
Effective shutter width is thus .06 mm which is far worse than the limitations of the metal surfaces, which will therefore be ignored.
Time of flight = 17 us.
The time-of-flight error is what limits the repeatability of the momentum measurement.
Temperature adds ~ +/- 8 ueV to the drift energy, or ~4 ppm in velocity.
This gives a scatter of 70 ps which is a little less than the timing error.
Just add the errors although this will be pessimistic:
Total measurement error < (100ps+70ps)/17us i.e. <10 ppm
The actual momentum of the electron is 600,000 * 10^-30.
The momentum measurement error is therefore 6 * 10^-30.
The actual positional measurement is defined by the metal surfaces to a few atomic dimensions, say 10^-9 m
The error product is thus 6 * 10^-39
Which is 5 orders of magnitude smaller than Planck's constant at 6.62 x 10^-34
