Heimdall
- 38
"Helmholtz equation" Neumann and divergence
Hello, I'm trying to solve the following elliptic problem :
S = B - \mu\nabla^2 B
Where S(x,y) and B(x,y) are 3 component vectors.
I have \nabla\cdot S = 0 and I want B such that \nabla\cdot B = 0 everywhere.
I'm using finite differences on a grid with nx+1 in the x direction and ny+1 points in the y direction. The x=0 and x=nx boundaries are periodic, so we have :
Bx(0,y) = Bx(nx,y)
By(0,y) = By(nx,y)
Bz(0,y) = Bz(nx,y)I thought that maybe the following boundary conditions would ensure \nabla\cdot B=0 : Bx(x,0) = B_1
Bx(x,ny) = B_2
\frac{\partial B_y}{\partial y}\left(x,ny\right)= \frac{\partial B_y}{\partial y}\left(x,0\right) = 0
(this make the divergence of B equal to zero on the y=0 and y=ny boundaries)
and homogenous dirichlet conditions for Bz at y=0 and y=ny.
Do you so far agree with that ?
I'm using centered second order scheme to discretize my equation (standard 5 point laplacien). And for the Neumann BC I'm doing :
By(x,-1) = By(x,1) for the y=0 border
By(x,ny+1) = By(x,ny-1) for the y=ny border.
This is supposed to be second order first derivative. Thanks to this, I can replace the "ghost" point in my Laplacian when I'm on the top or bottom border.
But I have a problem, when I look at \nabla\cdot B, it is 0 in the middle of my domain but on a small length from the y=constant borders, the divergence of B is starting to raise anormally.
example :
http://nico.aunai.free.fr/divB.png
another one (del dot B versus y-direction) :
http://nico.aunai.free.fr/divb.png
you can see that there is no problem at all on the periodic boundaries :-sWhen I'm solving the equation for an analytical source term for which I know the analytical solution, I can notice that there is a small error (but definitely bigger than everywhere else in the domain) on the Y boundary regarding to the Neumann BC.
Please, would you know where I should look at to fix this problem ?
Is my boundary conditions are bad to satisfy \nabla\cdot B=0 ?
Is my discretisation not correct ? I've checked the local truncation error which seems to be second order consistent, and eigenvalues of my linear operator looks pretty much the same that those of the Laplacian (1- L), and if I'm correct it should be stable and so converge towards the solution with second order accuracy everywhere, no ?
I can post my gauss-seidel routine if needed.
Thanks a lot !
Please tell me if something's not clear.
Bx(0,y) = Bx(nx,y)
By(0,y) = By(nx,y)
Bx(x,ny) = B_2
example :
Thanks a lot !
