Help Easy Physics - Resistivity Ratios
4 replies · 7K views
I-need-help
The resistivity of Aluminium is twice that of copper. However, the density of Aluminium is one-third that of Copper.
a) For equal length and resistance, calculate the ratio:
mass of aluminium/mass of copper​
I'm thinking, the density ratio (Al:Cu) is 1:3 ...and the resistivity ratio is 2:1 ...so would the overall ratio be, 2:3 ? I have no idea...
This is easy Physics compared to what else is on this site, but my physics isn't any good, so I joined this forum in hope that someone would be able to help me!
Thank you :)
Thank you :)
refer to the formula of resistance - often given as R = ρL/A - to see that one of the wires will have to be thicker - thus have a greater volume of metal, thus greater mass than if it was the same thickness.
Okay, thank you. I understand that, I'm just not sure how to get a ratio from that, with no other information... I'm not even sure if I need to work out a ratio actually. Oh well, thanks anyway.
Firstly, your original answer 2:3 was correct - but your uncertainty indicated you were not sure why.
When doing ratios, I just use the formulas and do a grand divide to produce the ratio.
In this case we want the ratio of masses.
Well I know density is mass/ volume [ σ = M/V] so
M = Vσ
Now the ratio: firstly put subscripts on the variable - I would use c for copper and a for aluminium
Ma = Vaσa
and
Mc = Vcσc
In ratio form:
Ma/Mc = Va/Vc x σac
We thus know
Ma/Mc = Va/Vc x 1/3
since we were given the ratio of the densities.
So now we need the ratio of the Volumes to complete this.
Each wire is effectively a cylinder
V =πr2h
For the wire, h = length of the wire - which is the same for both wires - so the ratio reduces to.
Va/Vc = ra2/rc2
So now we need the ratio of Radii [or diameters?]
Resistance is given by"
R = ρL/A
Since Area here is that of the circular wire,
R = ρL/∏r2
transposing
r2 = ρL/∏R
This gives
ra2 = ρaLa/∏aRa
and
rc2 = ρcLc/∏cRc
Now for these wires, Length and resistance [and of course ∏] are the same, so the ratio simplifies to
ra2/rc2 = ρac
Substituting back into:
Va/Vc = ra2/rc2
gives
Va/Vc = ρac
Then back into:
Ma/Mc = Va/Vc x 1/3
gives
Ma/Mc = ρac x 1/3
which gives
Ma/Mc = 2 x 1/3
which is 2/3 or 2:3 if you like.
While this has been lengthy to type out, when written it is much quicker.
Note: Normally the line:
ra2/rc2 = ρac
would be expressed as
ra/rc = √[ρac]
but I knew my previous formula had ra2/rc2 in it so I left it as was.
You can use this ratio technique to find the ratio of anything:
eg Ratio of two accelerations
F = ma → a = F/m
so
a1 = F1/m1
and
a2 = F2/m2
a1/a2 = F1/F2 x m2/m1
[Note that since m was in the denominator, is appears "upside down" as a ratio.]
SO once we know the ratio of the forces, and the ratio of the masses we can work out the ratio of the accelerations, without calculating/knowing the actual value of each acceleration.
Ahhhh okay, thanks so much for your help. Much appreciated. :)
