Help me understand indeterminism in standard quantum mechanics
  • Context: Undergrad
  • Thread starter Thread starter ojitojuntos
ojitojuntos
TL;DR
Hello. I’m having a hard time understanding indeterminism and the notion of collapse. Does indeterminism suggest that the future of the universe is not fully “set”?
Hello guys. Im having some trouble understanding the role of randomness in quantum mechanics, and what does that mean for the notion of an “open future”.
For example, let’s say I take a quantum event, like some atom decaying. Does indeterminism mean that, besides predictability, if it were possible to rewind time before that decay, the moment of decay would vary?
Thanks in advance!
Moderator's note: Thread moved to the QM interpretations subforum.
That role is interpretation dependent. In some interpretations, such as the MWI, there is no actual randomness anywhere; everything is entirely deterministic. The apparent randomness comes from the fact that the different branches of the wave function don't interfere, so in each individual branch, it appears as though one randomly chosen result happened. But actually, all possible results happen, each in its own branch.
Whereas, in interpretations where collapse is an actual physical process, the randomness is (or at least is claimed to be) inherent in whatever underlying dynamics produces collapses.
Again, the answer is interpretation dependent.
In the MWI, there are multiple branches of the wave function at which the atom decays at different times. If you "rewound" the wave function to the start and "re-ran" it again, exactly the same branches would arise, because everything is deterministic.
Whereas in interpretations where collapse is an actual physical process, yes, whatever underlying dynamics is producing collapses might produce one (i.e., might produce a detection of the atom decaying) at a different time if things were "re-run" again with exactly the same initial conditions.
Note that in practice it's never possible to re-run things again with exactly the same initial conditions, so there's no way of actually testing claims along these lines.
Just trying to contribute to the answer of PD here. In some interpretations, like Bohmian mechanics you get the same result every time because it is deterministic. It is deterministic without the need of parallel branches, but with the addition of hidden (nonlocal) variables.
But only if you force the exact same input state each time--which has to include the unobservable particle positions as well as the wave function. Whereas in the MWI, for example, all you have to "rewind" to get the exact same input state is the wave function.
Than you! If we assume the standard Copenhagen-like interpretations, does this mean that the evolution of the universe is fundamentally probabilistic? I know we can’t perfectly rewind or replicate all variables in an experiment, but I just find fascinating the idea that a fundamentally probabilistic outcome can derive from a given state.
I read that the 2022 Nobel was awarded to researchers who have basically constrained possible quantum interpretations, and that we have ti choose between non-locality and superdeterminism to keep a fully deterministic o outlook of reality.
Why I know that we’re talking about interpretations- can it be said that modern physics favors some type over others?
A standard Copenhagen-like interpretation doesn't take any position about what is really happening with "the evolution of the universe". All it says is that, when we make a measurement on a quantum system, we can only make probabilistic predictions about the results.
Such claims are debatable, because nothing about them can be tested by experiment--all QM interpretations make the same predictions for all experiments (because they all are interpretations of the same theory, QM, using the same or equivalent math). All they are really telling you about is the preferences of the people who make the claims about which interpretation they prefer.
No. See above about all interpretations making the same predictions.
  • · Replies 94 ·
  • · Replies 204 ·
13K
  • · Replies 175 ·
13K
  • · Replies 45 ·
  • · Replies 48 ·
  • · Replies 135 ·
12K
  • · Replies 109 ·
12K
