Why Does V Equal u Plus Delta v in Velocity Calculations?
  • Thread starter Thread starter Indranil
The equation V = u + Δv defines the relationship between final velocity (V), initial velocity (u), and change in velocity (Δv). Δv is explicitly defined as the difference between final and initial velocities, Δv = V - u. This relationship holds true regardless of whether acceleration is constant, making it applicable to any linear motion. The equation can also be expressed in vector form for multi-dimensional motion as Δv = V - u, where V and u are velocity vectors.
  • Understanding of basic kinematics concepts, including velocity and acceleration.
  • Familiarity with the definitions of final velocity (V), initial velocity (u), and change in velocity (Δv).
  • Knowledge of vector operations, particularly vector subtraction for multi-dimensional motion.
  • Basic algebra skills for rearranging equations and solving for variables.
  • Study the derivation of kinematic equations, particularly those relating velocity, acceleration, and time.
  • Learn about vector calculus and its application in physics, especially in motion analysis.
  • Explore the concept of instantaneous velocity and its relationship to average velocity.
  • Investigate real-world applications of these equations in physics, such as projectile motion and free fall.
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of motion and velocity calculations.
Indranil
V = u + delta v
[Here V = final velocity, u = initial velocity and delta v = change in velocity (v-u/t-t)]
As I know, a = v-u/t so, v = u + at
So could you explain why v = u + delta v?
V = u + delta v
delta v (or Δv) is defined to be the change in velocity. Change in velocity, in turn, is defined to be the final velocity (V) minus the initial velocity (u). So, by definition,
Δv = V - u.
Rearrange this to arrive at what you want to show.
Note that this result does not depend on using any acceleration equations. In particular, the acceleration need not be constant. The expression for Δv is valid for any motion along a straight line. The expression is a direct consequence of the meaning of "change in velocity".
For motion in 2 or 3 dimensions of space, there is a similar expression except that you would be working with velocity vectors:
##\Delta \vec v = \vec V - \vec u##
This is often written
##\Delta \vec v = \vec v_f - \vec v_i## where ##\vec v_i## and ##\vec v_f## are the initial and final velocity vectors, respectively. On the right hand side, you would be doing vector subtraction. This equation can be rearranged to get
##\vec v_f =\vec v_i + \Delta \vec v##
Indranil said:
V = u + delta v
V = u + delta v
Would it work better for you if we wrote ##\Delta v=at##?
Δv = ∫ dv = ∫ a dt
Δv = V - u.
You said above 'the acceleration need not be constant' so there is no any point using the acceleration, but what about the time (t)? as we know, delta v = vf-ui / t. Could you explain this part, please?
As has been said above, Δv = v - u, i.e. the change in velocity. That's what the symbol Δ means. It is NOT (v-u)/t, which is the average acceleration. If it was, you couldn't say v = u + Δv because the units of u and Δv wouldn't match.
Δv = V - u.
I don't understand this part 'Note that this result does not depend on using any acceleration equations. In particular, the acceleration need not be constant.' Could you please get this point easier for me so that I could understand the concept better?
If my initial velocity (u) is 10mph and I change my velocity (delta velocity) by +20mph my final velocity (v) is 30mph.
u + delta v = v
10 + 20 = 30
It's that simple.
The equation says nothing about how quickly the velocity changes (aka acceleration).
There are other equations that do relate initial and final velocity and time to acceleration.
  • · Replies 21 ·
  • · Replies 39 ·
