Help Needed: Solving Sequences with Standard Limits Equations
14 replies · 3K views
chief10
I'm having trouble with these here.. it's been a while since I've done sequences and I can't seem to make this work with Standard Limits equations.
Clearly the answer given by Wolfram solver is there after the = but i'd like to know the reasoning behind it.
Anyone that could point me in the right direction would be most helpful!
1.
2.
3.
thanks a lot
-chief10
1.
2.
3.
thanks a lot
-chief10
All you need to know is that [itex]e^x = \lim_{n\rightarrow \infty} (1 + \frac{x}{n})^{n}[/itex] and that if [itex]\lim f(x) = a[/itex] and [itex]\lim g(x) = b[/itex] with a,b≠∞, then [itex]\lim f(x) g(x) = a b[/itex]
haruspex said:
Do you know the standard limit result for (1+1/n)n? Yo can use that to solve 1 and 3.
so you just divide inside the brackets by 'n' right?
i don't get how the (n+1) part works with the particular standard limit though.. it's throwing me off a bit..
also what do you do with n^n..
ah yeah just your standard limit laws
how do you apply it to this one though..
I couldn't work it out
SL 7 didn't work for me.. any more tips?
Actually for the third one you don't need the definition of e.
0≤n[itex]^{n}[/itex]/(3+n)[itex]^{n+1}[/itex]≤ ?? which approaches 0.
dextercioby said:
You can also use the definition of e in terms of a limit for point 2, so you can have a common starting point for all 3. But using e for point 2 might be an overkill, though.
haruspex said:
Yes. Please post your working as far as you get.
This is what I've done for (1-(1/(n^2)))^n ===> I think it works
exp[lim(n→∞)n*log(1-(1/(n^2)))
let t = 1/n and use l'hospital's
exp[2*lim(t→0)(t/((t^2)-1))
then take the limit of each individual component inside the exponent and you should be left with exp(2*0/0-1) = exp(0) = 1
sound about right?
reckon i should do the same thing [exp(log)] type approach for the others?
could you elaborate further? I've never seen that concept before
for number 1 i can't seem to solve it using exp[log]...
l'hospital's doesn't work since the denominator is 1..
Number 1 might be conceptually easier if you first write m = n+2 and consider m→∞. You can split it into two fractions, after which the rule I mentioned earlier becomes useful.
You know that the sequence is positive, if you show that the sequence is bounded by another sequence and that bounded sequence approaches 0, then you can deduce that your original sequence is 0. Similar concept to squeeze theorem.
For the second one you can do in 1 step. Factor it then apply the definition of e^x and you get 1/e * e = 1.
