Help : Perpendicular distance of the plane
The discussion focuses on calculating the perpendicular distance from the origin to the plane defined by the equation 5x + 2y - z = -22. The solution involves setting x and y to zero to find the z-coordinate of the intersection point on the plane, which yields the absolute value of z as the perpendicular distance. Additionally, the use of Lagrange Multipliers is suggested as a method to minimize the distance from the origin to any point on the plane while adhering to the constraint of the plane's equation.
  • Understanding of plane equations in three-dimensional space
  • Familiarity with vector normal to a plane
  • Knowledge of Lagrange Multipliers for optimization problems
  • Basic calculus concepts related to distance minimization
  • Study the method of Lagrange Multipliers in depth
  • Learn how to derive the normal vector from a plane equation
  • Explore parametric equations of lines in three-dimensional space
  • Practice problems involving perpendicular distances from points to planes
Students studying multivariable calculus, mathematicians interested in optimization techniques, and anyone seeking to understand geometric interpretations of planes and distances in three-dimensional space.
ahgang
Find the perpendicular distance of the plane 5x+2y-z=-22 from the origin O by first finding the co-ordinates of the point P on the plane such that OP is perpendicular to the given plane.
It only given plane vector,how i going to figure out the perpendicular distance?
I really don't know where to start.Can help to elaborate?
Thanks
Set x and y equal to zero, solve for z. The perpendicular distance will be the absolute value of this number.
You mean (X,Y.Z) = (0.0.Z)?Then minus the plane location?
One option is to use Lagrange Multipliers to get the coordinates of the point by treating it as a minimization problem (i.e. distance from origin to an arbitrary point) with the constraint that the arbitrary point must lie on the plane. Hint: minimizing the square of the distance also minimizes the distance.
You should be able to write a normal to the plane by inspection of the defining equation. Any line that is perpendicular to the plane must be parallel to this normal. So write a parametric equation of a line that passes through the origin that lies along this normal vector. Where does this line intersect the plane?
