Chemistry Help please with this chemistry molar calculation
The discussion focuses on a chemistry molar calculation involving sodium bicarbonate (NaHCO3) and sodium carbonate (Na2CO3). It highlights the assumption of starting with equal molar amounts of both compounds, which leads to incorrect calculations. Participants suggest setting up simultaneous equations to solve for the individual masses of NaHCO3 and Na2CO3 in a 0.500g sample. There is also a clarification on converting between units, specifically moles per cubic centimeter, emphasizing the need for accuracy in calculations. The conversation underscores the importance of careful work, particularly when switching from digital to manual calculations.
TheePhysicsStudent
I was practising questions from a book printed in the 1980s, and I'm unsure where I went wrong with this Q, the answer is 68.2%
I dont use equations for chemistry mole calculations, i just think my way through it so I don't know
The question
My Working:
In your initial hand-written equation, you have “##NaHCO_3 \cdot Na_2CO_3##. This means you have implicitly assumed that you are starting with equal (molar) amounts of ##NaHCO_3## and ##Na_2CO_3##. It goes wrong from there.
Suppose the 0.500g of reactant contains x grams of ##NaHCO_3## and y grams, of ##Na_2CO_3##.
Can you set up 2 simultaneous equations for x and y and solve them?
Edit: ask for hints if you can't!
Likes TheePhysicsStudent
1 dm^3 = 1000 cc, so 15 cc of the acid solution contains ?? moles of HCl?
Maybe this could reassure you or maybe not:
1 decimeter is 10 centimeters.
(careful! these two lines have a mistake.)
0.100 mole/(dm^3) * (10/1)^3(dm/cm)^3
100 mole/(cm)^3
THAT above is obviously wrong. This is the kind of trouble I have when I do things strictly through keyboard and computer screen. My work later using pen and paper was bettter.
Should have that been like so:
0.100 (moles/dm^3)*(1/10)(dm/cm)(1/10)(dm/cm)(1/10)(dm/cm)
0.100(1/1000)(moles/cm^3)
0.000100 moles per cubic centimeter
100 mole/(cm)^3
0.1 mole/1000cc=##0.0001\ moles/cc##
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
11K
