What Are the Possible Values for R in a Parallel/Series Resistor Setup?
  • Thread starter Thread starter NotaPhysicsMan
    Resistors
The discussion centers on calculating the possible values for resistance (R) in a circuit where a resistor is connected in both parallel and series configurations with a 2.00 ohm resistor. The user correctly applies Ohm's Law (I=V/R) and derives the equations for current in both configurations. The final quadratic equation derived is R² - 6R + 4 = 0, yielding two solutions: R = 5.236 ohms and R = 0.7639 ohms. The calculations and thought process are validated by other participants in the discussion.
  • Understanding of Ohm's Law (I=V/R)
  • Knowledge of series and parallel resistor configurations
  • Ability to solve quadratic equations
  • Familiarity with equivalent resistance calculations
  • Study the derivation of equivalent resistance in parallel circuits
  • Learn how to solve quadratic equations in electrical engineering contexts
  • Explore advanced circuit analysis techniques using Kirchhoff's laws
  • Investigate practical applications of series and parallel resistor combinations in real-world circuits
Electrical engineering students, circuit designers, and hobbyists interested in understanding resistor configurations and circuit analysis techniques.
NotaPhysicsMan
Ok the question is:
A resistor (resistance=R) is connected first in parallel and then in series with a 2.00 ohm resistor. A battery delivers five times as much current to the parallel combination as it does the series combination. Determine the two possible values for R.
So let's see: I can use I=V/R
For series it's I=V/(R+2)
For parallel it's 5I=V/(1/R+1/2ohm) Ok, now I equate the Currents (I)
and I get V/(R+2)=V/5(1/R+1/2). I can cancel out the V's and I'll have:
Now I solve for R?
Am I on the right track? :confused:
Your parallel equation is wrong:
R_{eq}=(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})^{-1}
So if you say I=\frac{V}{R_{eq}} you end up with:
I=\frac{V}{(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})^{-1}}
or more simply:
I={V}{(\frac{1}{R_1}+\frac{1}{R_2}+\cdots+\frac{1}{R_n})}
Your thought process is correct though.
Good luck.
Your equation for equivalent resistnace in a parallel circuit is wrong. The correct equation is:
\frac{1}{R} = \frac{1}{R_1} + \frac{1}{R_2}
Otherwise you seem to be on the right track.
Ok this is weird. Ok so jumping to the equating of the two equation step...
I get :
V/(R+2)=V/5 x (1/R+1/2). Now, I cancel the Vs and try to solve for R
1/(R+2)=1/5 x (1/R+1/2). Now I bring the 5 over on the otherside and now I will solve and get a quadratic equation:
R^2-6R+4=0. Solving for R's I get R=5.236 and R=.7639 ohm.
It looks right? Thanks.
  • · Replies 24 ·
  • · Replies 42 ·
