Help solving problem involving inequalities
  • Context: Graduate
  • Thread starter Thread starter mlearner
    Inequalities
The discussion revolves around solving an inequality problem from an analysis textbook, specifically regarding the continuity of a function in the context of rational numbers. Participants are exploring various approaches to demonstrate that if \( x^2 < 2 \) and \( \delta = \frac{(2 - x^2)}{6} \), then \( y^2 < 2 \) whenever \( |x - y| < \delta \).
  • One participant suggests that \( |x - y| < \frac{(2 - x^2)}{6} < \frac{1}{3} \) implies \( y < \frac{1}{3} - x < \frac{1}{3} + \sqrt{2} < 2 \), but this is challenged for not addressing the requirement that \( y^2 < 2 \).
  • Another participant emphasizes the need to find the region in the \( x,y \) plane that satisfies the inequalities and proposes considering cases where \( y > x \) and \( y < x \) separately.
  • A different approach is presented where it is suggested to manipulate the inequality to show \( y^2 < x^2 + d^2 + 4d \) and derive the result from there.
  • One participant attempts to substitute \( \sqrt{2} \) for \( x \) to derive conditions on \( y \), but this is critiqued for not adhering to the constraints of the problem, particularly the requirement that \( x \) must be rational.
  • Another participant points out that the substitution of \( \sqrt{2} \) is invalid due to the specified domain of rational numbers and the implications of the absolute value in the context of the problem.
Participants express differing views on the validity of various approaches to the problem. There is no consensus on a single method, and several participants challenge each other's reasoning and assumptions.
Some participants note that the problem requires a solution applicable to all values of \( x \) and \( y \) satisfying the inequalities, rather than specific instances. There is also an emphasis on the importance of remaining within the realm of rational numbers, as the problem explicitly states.
mlearner
Hi all,
I'm trying to teach myself analysis using the book "A Companion to Analysis: A Second First and First Second Course in Analysis" by T. W. Körner.
There's an inequality problem in there that's used to prove a statement about the continuity of a function, that I've got stuck in (problem 1.16, part (iii), in case you happen to have the book):
Working in \mathbb{Q} (the space of rational numbers), if x^2&lt;2 and \delta=\frac{(2-x^2)}{6}, show that y^2&lt;2 whenever |x-y| &lt; \delta
Any help would be greatly appreciated!
How about |x-y|<(2-x^2)/6<1/3, thus y<1/3-x<1/3+sqrt(2)<2 since sqrt(2)=1.41.. and 1/3=0.33..
That doesn't seem to be quite correct...
It needs to be proven that y^2 &lt; 2, not y &lt; 2 - the latter doesn't imply the former.
Also, I have the feeling the author expects a solution that doesn't explicitly using the value of \sqrt{2}, since no such rational number x exists such that x^2=2.
The best way to approach it is to find the region in the x,y plane that satisfies the inequalies.
With the |x-y| term you're best off to consider the two cases (x>y and x<y) separately.
For example.
Case1. Assume y>x
y < 1/3 + x - x^2 /6.
That is, we are looking for the region of the x,y plane where both y>x and y < 1/3 + x - x^2 /6 are satisfied. It's pretty straight forward to find, just the region between a parabola and a straight line.
Repeat for the other case (y<x) and you'll soon know everything that you could wist to kinow about the solution region and the inequality y^2<2 will be immediately apparent.
Thanks for the replies... I posted the same problem on Usenet sci.math, and was offered a simpler solution (although I managed to solve the problem myself in pretty much the same way immediately after posting the question on sci.math - funny that).
|x-y| < d (d is delta)
=> |y| < |x| + d
=> y^2 < x^2 + d^2 + 2|x|d < x^2 + d^2 + 4d
and then showing d^2 + 4d < (2-x^2)
from which the result follows.
Will this way work?:
|x-y| < (2-x^s)/2
Substitute sqrt (2) for x, and you get
sqrt (2) - y < 0
- y < - sqrt (2)
y > sqrt (2)
y^2 > 2
_____________________________________
sqrt (2) - y > 0
- y > - sqrt (2)
y < sqrt (2)
y^2 < 2So therefore, y^2 does not equal 2, and you get your answer of y^2 < 2
Ah no, you have to show it for all values of x and y that satisfy the inequalities, not just a specific set.
|x-y| < (2-x^s)/2
sqrt (2) - y < 0
- y < - sqrt (2)
y > sqrt (2)
y^2 > 2
Nah, that's not right, for at least two reasons: (1) It is clearly specified that x^2 < 2, i.e. -sqrt(2) < x < sqrt(2), so a substitution of x = sqrt(2) is not justified, and in fact leads to |sqrt(2)-y|<0 , which can never be true (because the absolute value of a number is either greater than or equal to zero). (2) A second reason is that we're dealing in rational numbers (as specified in the original problem): sqrt(2), for us, "doesn't exist", so such a substitution would be "cheating" (even if problem (1) didn't exist).
IMO, the easiest-to-follow solution is the one outlined in my previous post. I'll "latexify" it and fill in the missing steps in my next post, in case someone's interested.
  • · Replies 16 ·
