What is the Mystery Opamp in this Vintage Equipment?
  • Thread starter Thread starter JohnNNN
    Opamp
The forum discussion centers on identifying a mystery operational amplifier (opamp) in vintage equipment, specifically a poorly stamped component likely from the late 1970s. Participants suggest that the opamp could be an LM318, a fast bipolar opamp, and discuss the possibility of it being a military part with a designation of M38510/00318. The conversation emphasizes the importance of tracing the circuit and examining the PCB layout to confirm the component's function and origin.
  • Understanding of operational amplifiers, specifically LM318 characteristics.
  • Familiarity with PCB layout design and standard op-amp supply lines.
  • Knowledge of military part number systems, particularly MIL-M-38510.
  • Experience in vintage electronics restoration and schematic tracing.
  • Research the specifications and applications of the LM318 operational amplifier.
  • Explore the MIL-M-38510 part numbering system and its historical context.
  • Investigate techniques for tracing and analyzing vintage PCB circuits.
  • Look for cross-reference lists for military and commercial part numbers.
This discussion is beneficial for electronics enthusiasts, vintage equipment restorers, and engineers involved in identifying and replacing obsolete components in legacy systems.
JohnNNN
Hi, pals! I'm in process of restoring vintage equipment. And I was failed to identify one of the operational amplifiers.
Does anyone have any idea what kind of animal this is? This is link to opamp photo: https://postimg.cc/HVZ2hjRm
Welcome to PF, John. :smile:
That's a strange photo. Did you add the orange lettering to enhance the photo to make it more readable? If not, it looks like the component has been "black topped" and re-labeled (note how the pin-1 mark misregisters between the orange marking and the injection molded mark).
What year is this PCBA probably from? Paging @davenn and @Baluncore for their expertise...
Edit/Add -- what exactly is this piece of vintage equipment? Have you had any luck at all trying to find the schematics? I'm guessing probably not... Have you been able to trace most of the circuit to decide that this is an opamp? Have you tested the circuit powered-up (hopefully using an Isolation Transformer if it is AC Mains powered) and been able to measure the DC and AC voltages at this component's pins?
I just did a Google search and got this TI page:
https://www.ti.com/lit/ds/symlink/t...28778&ref_url=https%3A%2F%2Fwww.google.com%2F
  • Love
Wow, thanks Don. Sorry I paged the wrong @d____ !
I have trouble keeping meteroids and earthquakes and vintage equipment expertise straight in my tiny little brain! o0)
  • Haha
... my tiny little brain!
Now, I know that's wrong!
My guess would be the late 1970s. The chip was poorly stamped.
I think the partial trademark 'D' with the internal dot, will be a big clue.
But I can't yet find my old list of (TM) symbols from the industry.
Maybe 00318 is a military manufacturer prefix, with product as -029.
As a second or third source, there may have been very few made.
Search in the JEDEC equivalent lists?
Yes. This is likely the correct approach.
Also, large equipment manufacturers will have their own part numbers assigned and have the suppliers label them as such. HP, for example, nearly always did this (although this one doesn't fit the HP format). If you can find a cross-reference list, maybe JEDEC (Mil parts) or from the OEM, you will likely find it is actually a common part.
Sorry, I don't recognize the manufacturer graphic on it. It's not one of the big US companies.
Who was the OEM for this PCBA?
DaveE said:
Nope. We're looking for something in a DIP-8, this has way too many pins. It's likely too new also (2016).
Dang, You're right. Sorry about that. So the one @hutchphd posted in post #6 above is the right one?
https://www.ti.com/product/LM318-N
Well, I wouldn't assume that. But if you put a gun to my head and no time to research, that would be my guess. I'd sketch out the circuit it's in first and try to guess the application/function. For example, is it one amp or two, etc. ?
A 318 is a fairly fast opamp. I have to wonder if there would be a good reason to have something that fast in the equipment that it is in.
The 318 would have had LM in front of it's number if it was the fast bipolar amp. LM stands for Linear Monolithic.
We still do not have a functional description or picture of that PCB. Without a date code from some other component we are out of clues.
Was it US Govt, British or a European design?
Do we even know it's an opamp...
The layout of tracks on the component side of the PCB are the standard op-amp supply lines. That was an optimal manual routing technique that held power on the component side, signals on the solder side, and used components or wire links to cross tracks.
There was a 5 digit military part number system known as 'MIL-M-38510' with a date sequential numbering system. Many of the early parts have 00xxx format numbers, but I found no reference to 00318 in the year 1977. M38510 was then used for linear chips by AMD, Fairchild, Intersil, NSC, Dignetics and TI.
The dotted 'D' icon that looks like an OR gate is not a TM for any of them, so there must be another manufacturer and military M38510 tester of those chips.
I would next look for a full part number "M38510/00318" and convert that through a mid-1970s list, from the military to a commercial part number.
It would be nice to have some information from outside that square inch.
Given the high level of participation in this thread by the OP @JohnNNN that may be hard for us to get... :wink:
You mean PF helps those who help themselves? I think I'm done.
PS: Wait, I'm not implying I think we're god.
But I have forsaken him.
  • Love
  • Haha
Oh c'mon. Let's all have some fun and say we've got it completely figured out and when asked what it is just say: Sorry, not tell'n.
  • Haha
  • · Replies 43 ·
12K
  • · Replies 27 ·
  • · Replies 20 ·
  • · Replies 30 ·
25K
  • · Replies 16 ·
