Help understanding equivalent definitions for continuity
2 replies · 3K views
TaliskerBA
I was hoping someone could help me understand the equivalence between the definitions for functions to be continuous between topological spaces, ie:
For X and Y topological spaces, and f:X-->Y a function, my notes don't prove why these definitions are equivalent (possibly because I'm missing something pretty obvious!):
1. f continuous IFF for U open in Y f^-1(U) is open in X
2. f continuous IFF for C closed in Y, f^-1(C) is closed in X
I can see why this is true when f is surjective, because then f^-1(Y) = X, so for F closed in Y, U=Y\F is open in Y and f^-1(Y) = f^-1(U u F) = f^-1(U) u f^-1(F) (because U and F are disjoint) so X = f^-1(U) u f^-1(F) implies f^-1(U) = X\f^-1(F) open in X (and then it is also easy to see the converse here). But if f is not surjective, then all that follows is that f^-1(U) is in X\f^-1(F) (open in X), so why does it follow in this case that f^-1(U) is open in X, given definition 2?
You can show [itex]f^{-1}(Y\setminus C) = X\setminus f^{-1}(C)[/itex], because [itex]x\in f^{-1}(Y\setminus C) \Leftrightarrow f(x) \in Y\setminus C \Leftrightarrow f(x) \notin C \Leftrightarrow x\notin f^{-1}(C) \Leftrightarrow x\in X\setminus f^{-1}(C)[/itex]. Now let's say f is continuous by the open set definition. Then [itex]C \text{ closed } \Rightarrow Y\setminus C \text{ open } \Rightarrow f^{-1}(Y\setminus C) \text{ open } \Rightarrow X\setminus f^{-1}(C) \text{ open } \Rightarrow f^{-1}(C) \text{ closed}[/itex] using continuity at the second step and the statement from above at the third. The other way around works the same.
Hey belated thanks for your help. Quite obvious in the end!
