Help understanding minkowski tensor and indices
The discussion centers on understanding the transformation of covariant two tensors and the Minkowski metric tensor under Lorentz boosts. The transformation is expressed as A'_{\mu \nu}=(L^{-1})_{\mu}\ ^{\kappa}(L^{-1})_{\nu}\ ^{\lambda}A_{\kappa \lambda}, with clarification needed on matrix multiplication order and interpretation of indices. The invariance of the Minkowski metric tensor under Lorentz boosts is also examined, with participants suggesting that the relationship between raising/lowering indices and Lorentz transformations is crucial. Additionally, there is confusion regarding different conventions for the Minkowski metric, which can be represented as either -1,1,1,1 or 1,-1,-1,-1. The conversation concludes with advice to focus on tensor notation rather than matrix notation for clarity in understanding transformations.
decerto
So I have just been introduced to indices, four vectors and tensors in SR and I'm having trouble knowing exactly what I am being asked in some questions.
So the first question asks to write explicitly how a covariant two tensor transforms under a lorentz boost.
Now I know that it transforms like A'_{\mu \nu}=(L^{-1})_{\mu}\ ^{\kappa}(L^{-1})_{\nu}\ ^{\lambda}A_{\kappa \lambda}
where L is the matrix with L_{00/11}=\gamma and L_{12/21}=-\gamma \beta
Is this written explicitly or do I need to write it out in matrix form and if so what is the order of the matrix multiplication, how do I interpret from the indices what the order is?
The next questions asks to show that the covariant form of the minkowski metric tensor is invariant under this lorentz boost. What I have so far is \eta'_{\mu \nu}=(L^{-1})_{\mu}\ ^{\kappa}(L^{-1})_{\nu}\ ^{\lambda}\eta_{\kappa \lambda}
\eta'_{\mu \nu}=(L^{-1})_{\mu}\ ^{\kappa}(L^{-1})_{\nu \kappa}
I'm not really sure how to proceed from there, I'm pretty sure there is some relationship between raising/lowering indices and the inverse of lorentz transformation I'm not aware of.
Also I've seen the minkowski metric written both -1,1,1,1 and 1,-1,-1,-1 on various pdfs/notes online why is this?
And finally is there a link to some proof that the L I described acts on contravariant components and not covariant, i.e somethat shows the basis vectors of minkowski space transform by L^-1?
I can't provide an answer to a homework question directly, but I can help with this general question you raised:
Index notation is more general than matrix notation, so some expressions can be written in matrix form and other cannot. Generally, writing an index expression as a matrix requires that summed indices be adjacent.
(L-1)μκ (L-1)νλ Aκλ rewrite as (L-1)μκ Aκλ (L-1)νλ
Now the κ's are adjacent, but the λ's are not. To get them adjacent, use a transpose: Vαβ = (Vβα)T. So
(L-1)μκ Aκλ (L-1)νλ rewrite as (L-1)μκ Aκλ (L-1)Tλν
and the matrix form of the expression becomes L-1 A (L-1)T.
Can you give any indirect advice for the homework question or should I post it to the homework section of the site?
I would suggest forgetting about matrix notion and trying to grasp directly with the tensor notation. You know about the Einstein convetion, that repeated indices are summed over, I assume?
It may be painful, but if you have to , expand the shorthand tensor notation into the full sum, i.e.
##\left(x'\right)^a = \Lambda^{a}{}_{b} x^b ## in shorthand tensor notation is equivalent to the follow set of four equations written fully out:
##\left(x'\right)^0 = \Lambda^{0}{}_{0} x^0 + \Lambda^{0}{}_{1} x^1 + \Lambda^{0}{}_{2} x^2 + \Lambda^{0}{}_{3} x^3 ##
##\left(x'\right)^1 = \Lambda^{1}{}_{0} x^0 + \Lambda^{1}{}_{1} x^1 + \Lambda^{1}{}_{2} x^2 + \Lambda^{1}{}_{3} x^3 ##
##\left(x'\right)^2 = \Lambda^{2}{}_{0} x^0 + \Lambda^{2}{}_{1} x^1 + \Lambda^{2}{}_{2} x^2 + \Lambda^{2}{}_{3} x^3 ##
##\left(x'\right)^3 = \Lambda^{3}{}_{0} x^0 + \Lambda^{3}{}_{1} x^1 + \Lambda^{3}{}_{2} x^2 + \Lambda^{3}{}_{3} x^3 ##
I've written the transformation matrix with indices as shown (northwest to southeast) because that's what my textbook (MTW) prescribes. I noticed yours was opposite, and it looks funny to me but I can't be positive that MTW"s conventions are universal.
If it's an undergraduate course, it should be posted to the homework sections. Homework in graduate courses may be posted to the forums.
You are right. It's very important not to write the indices on top of each other. By definition the contravariant components transform as you've written
x'^a={\Lambda^a}_b x^b.
Now let's see, how the covariant components transform
x'_a=\eta_{ab} x'^b=\eta_{ab} {\Lambda^{b}}_{c} x^c = \eta_{ab} {\Lambda^{b}}_{c} \eta^{cd} x_d.
Usually one defines
\eta_{ab} {\Lambda^{b}}_{c} \eta^{cd}={\Lambda_a}^{d}.
Then you have
x'_a={\Lambda_a}^b x_b.
Now let's check that this is indeed correct, i.e., that the covariant components indeed transform contragrediently to the contravariant ones as it must be.
To that end we have to use the fact that we deal with Lorentz transformations, i.e., pseudo-orthogonal transformations wrt. the fundamental form \eta_{ab}. That means that
\eta_{ab} {\Lambda^a}_c {\Lambda^{b}}_d=\eta_{cd}.
Contracting with the inverse transformation, we get
\eta_{ab} {\Lambda^a}_c = \eta_{cd} {(\Lambda^{-1})^{d}}_{b}.
Contracting with the fundamental form we find
\eta_{ab} \eta^{cd} {\Lambda^a}_c={\Lambda_b}^{d}={(\Lambda^{-1})^d}_b.
QED.
So it's
x_a'={\Lambda_{a}}^b x_b={(\Lambda^{-1})^b}_a x_b.
This should also the OP's question (correcting the assumption in the very beginning!).
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 16 ·
