Help with infinite sequences and series
The discussion revolves around infinite sequences and series, specifically focusing on convergence tests and summation formulas. Participants are addressing problems labeled as A and B, as well as a third problem related to convergence criteria.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of the comparison test and ratio test for series convergence. There is mention of using known formulas for summing natural numbers and partial fraction decomposition. Questions arise about the convergence of specific series and the handling of variable exponents.
Some participants have provided hints and formulas related to the problems, while others express confusion and seek clarification on specific steps. Multiple interpretations of the problems are being explored, particularly regarding the convergence of series and the evaluation of sums.
Participants mention feeling overwhelmed by the pace of their coursework and express uncertainty about their understanding of key concepts, such as partial fraction decomposition and convergence criteria. There is a suggestion to look up formulas or seek additional resources for clarification.
suprajzturbo
Member warned that template must be used and an effort shown
I tried the comparison test for one B but not sure if I am right. Think it could also be a ratio test because of the variable exponent. I'm lost totally lost on number one A. Also, I have the answer for the first part of three but don't know how to do the second part of it by comparing.
Thanks
For A, do you know that [itex]1+ 2+ 3+ \cdot\cdot\cdot + k= \frac{k(k+1)}{2}[/itex]?
For B, [itex]\sqrt{k}- \sqrt{k+1}= \frac{(\sqrt{k}- \sqrt{k+1})(\sqrt{k}+ \sqrt{k+ 1}}{\sqrt{k}+ \sqrt{k+1}}= \frac{-1}{\sqrt{k}+ \sqrt{k+1}}[/itex]
For 3, you say you have already determined the values of p such that the given series converges. Okay, for what values of p does [itex]\sum_{n= 1}^\infty \frac{1}{n^p}[/itex] converge?
Hint: For 1(a) first recall the formula for the first ##k## natural numbers, then use partial fraction decomposition. After that, you will see lots of things cancelling.
Thanks
Do you know how to evaluate the sum ##1+2+3 + \cdots + k##? I cannot believe you have not seen it before, and if not, try a Google search.
Ray, isn't the limit of k the summation? So, it would be infinity? I just finished reading sequences and series but prof. is already 3 sections ahead. Stewart's Calculus isn't helping so these instructional google videos (e.g. Khan Academy and prof. Leonard) slow me down. Halls of ivy, how did you get rid of the variable exponent? Krylov, I'm not really good at partial fraction decomposition and the only formula I know is two from geometric series and just bunch of theorems at the moment.
In 1(a) your sum has the form
[tex]S = \frac{1}{1} + \frac{1}{1+2} + \frac{1}{1+2+3} + \cdots + \frac{1}{1+2+ \cdots + k} + \cdots[/tex]
I am asking you if you can find a formula for the ##k##th term of the sum; later on, you can worry about whether the sum is convergent. But first, you need to get the kth term in a more manageable form.
As I said, if you do not know the sum in the denominator of term k, you can go to the library and look it up, or nowadays do an on-line search.
