Help with Integral Problem: Tips to Get Started
  • Context: MHB
  • Thread starter Thread starter Samme013
    Integral
The discussion revolves around a challenging integral problem involving the substitution method and differentiation. Participants explore various approaches to evaluate the integral, including substitution techniques and differentiation with respect to parameters.
  • One participant expresses difficulty with the integral and mentions several unsuccessful attempts at substitution and limits.
  • Another participant suggests using the substitution \( \frac{1}{x} = t \), leading to a transformed integral that may be easier to evaluate.
  • There is a discussion about differentiating the integral equation with respect to a parameter \( a \), leading to a quadratic equation.
  • One participant reports obtaining two roots from the quadratic, questioning the validity of the positive root.
  • Another participant corrects the focus to the negative root of the quadratic, indicating that it is the relevant solution.
  • One participant presents a different approach using substitution and expresses confusion about the limits of integration and the resulting values for \( a \).
  • Another participant points out an error in changing the limits of integration and suggests that the improper integral does not converge, reiterating the usefulness of differentiation.
Participants do not reach consensus on the best approach to solve the integral, with multiple competing views and methods discussed. There is uncertainty regarding the validity of certain substitutions and the convergence of integrals.
Limitations include unresolved mathematical steps, particularly regarding the evaluation of improper integrals and the implications of parameter differentiation. The discussion reflects varying interpretations of substitution techniques and their consequences.
Samme013
Ok so i am stuck on this problem , i tried substituting 1/x for u did not help , tried turning it into a limit where the top integration limit would be c and c-->0 did not get anywhere.Also tried substituting f(x) for its anti derivative [-e1/x] with no luck.So yeah at least some tips to get me started would be much appreciated.
Samme013 said:
https://www.physicsforums.com/attachments/3410
Wellcome on MHB Samme013!...
... the substitution $\displaystyle \frac{1}{x} = t$ may be useful because...
$\displaystyle \frac{1}{x} = t \implies x= \frac{1}{t} \implies d x = - \frac{d t}{t^{2}} \implies \int \frac{e^{\frac{1}{x}}} {x^{2}}\ d x = - \int e^{t}\ d t\ (1)$
Kind regards
$\chi$ $\sigma$
Kind regards
$\chi$ $\sigma$
Thanks !, i tried that but i get the following:
$\ \lim_{{c}\to{\infty}} \int_{c}^{1/a} \,e^t dt = f(a)=\lim_{{c}\to{\infty}} e^(1/a) - e^c $
Which is just -infinity and does not help me find a
Try differentiating the integral equation given with respect to $a$...this leads to a quadratic in $a$, for which you discard the positive root.
Awesome , i took the partial derivative with respect to a on both sides and got two answers , 1 posiive , a = $\sqrt{2} - 1$ is that right?
You should obtain:
$$a^2-2a-1=0$$
You want the negative root ($a<0$), which is $$a=1-\sqrt{2}$$
MarkFL said:
You should obtain:
$$a^2-2a-1=0$$
Derp yeah thought a was positive , that was the other root i got , thanks !
MarkFL said:
You should obtain:
$$a^2-2a-1=0$$
Just tried something else and got a different answer:
by substituting u= 1/x and if we get :
$ f(a) = \int_{-\infty}^{1/a} \,d e^t ft = e^(1/a) = [e^(1/a)]/a^2]$ ... a = 1 or a = -1 so a = -1.
Did i do something wrong or is it not possible to take partial derivatives like we did before since a is a contant?
I'm not following what you did there, can you restate it?
for u=1/x , du=-1/x^2 dx so substituting into the given integral and changing the integration limits sice x=a -> u=1/a and when x-->0 u--->-infiniy since x approaches 0 from the left sice in the given integral a is the other integration limit and is negative so:
$f(a)=-\int_{1/a}^{-\infty} \, e^u du =- \lim_{{c}\to{-\infty}} \int_{1/a}^{c} \, e^t dt = \lim_{{c}\to{-\infty}} -e^c +e^(1/a)=e^(1/a)=f(a)=[e^(1/a)]/a^2] $
so solving the equation for a a =1 or a = -1 so we keep a = -a <0
Okay, if you try the substitution:
$$u=\frac{1}{x}\,\therefore\,du=-\frac{1}{x^2}$$
Then, the integral becomes:
$$\int_{\infty}^{\frac{1}{a}}e^u\,du$$
You have incorrectly changed the limits of integration...since:
$$u(x)=\frac{1}{x}$$
We find:
$$u(0)=\infty\,u(a)=\frac{1}{a}$$
Trying to evaluate the resulting improper integral above does not result in a converging value. This is why I suggested using differentiation.
