Help with Physics - Object submerged, displacement, density, pressure?
The discussion revolves around physics problems related to pressure, density, and buoyancy. The original poster presents multiple questions involving calculations of pressure exerted by a submerged object, the density of a metal piece based on water displacement, and the pressure at a certain depth in a lake.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of pressure from a weight and area, questioning the values used for gravitational acceleration. There is confusion regarding the density calculation based on volume displacement and the relationship between liters and cubic meters. Additionally, participants explore the equations related to pressure variation with depth and the total pressure considering atmospheric pressure.
Participants are actively engaging with the problems, asking for clarification on specific calculations and definitions. Some have provided insights into the importance of unit conversions and the need for a complete problem statement. There is no explicit consensus on the solutions, but several participants are guiding others to reconsider their calculations and assumptions.
There is a noted emphasis on showing work for each problem, as the forum encourages understanding over simply providing answers. Participants express frustration over the lack of example problems in the original poster's textbook, which may contribute to their confusion.
bpears
I have a few physics problems I need help with. Please show work or I won't know how to do it. My book has no example problems.
1. Suppose you balance a 5kg ball on the tip of your finger, which has an area of 1 cm^2. Show that the pressure on your finger is 49N/cm^2, which is 490kPa.
-For this question I get 500kPa, where is the -10kPa coming from?
2. 6kg piece of metal displaces 1 Liter of water when submerged. Show that the density is 6000kg/m^3
3. Deepest part of a lake has depth of 406m. Show that water pressure at this depth is 3978.8 kPa, and the total pressure there is 4080.1 kPa.
How about YOU show your work? Then we can show you where you went wrong.
We're not just going to give you fully worked out solutions.
Yeah, well I don't even know where to begin. I can tell it is simple but I don't know what I need to do. If you honestly believe I'm just trying to have u do my home work, then use different numbers. I just want to know HOW to do these. Thanks.
I meant show us your work for the specific problem that I quoted. How did you arrive at 500 kPa? If you show me your steps, I can tell you where you made your mistake.
For problem 2: What must the volume of the 1 L of displaced water be equal to?
For problem 3: what is the equation for the variation of pressure with depth?
THere is a reason why this site has a template for homework help posts that includes a complete statement of of the problem, a list of any *relevant equations*, and the work you've done so far. The second item, in particular gets you thinking about what physical relationships and principles are important to the problem.
I second the stuff cepheid said. Also, for question 1, it looks like bpears has used g=10m/s^2 and the answer book used g=9.8m/s^2, so the difference in answers is only due to using different values for g.
Bruce, you are spot on. My instructor tells us to just use 10m/s^2 for gravity. Which I now see was a bad idea for our book. So, I get the 1st one. But the other two, I don't know how to do.
For number 2, I see that if it displaces 1L, then it must have the volume of 1L? And its safe to assume that the 1000 is multiplied by 6kg, but where does the L unit go? And what formula are you supposed to use on this?
For number 3, I know P=pgh. so P=p(9.8m/s^2)(406m)
Which without multiplying the density I get the 3978.8kPa. But I don't know why? What about density(p)? And then I don't know how to get total pressure of 4080.1kPa?
For number 2, use the DEFINITION of density to compute the density.
for part 3) you need to look up the density of water.
To elaborate on this, I should point out that you most certainly
are not getting 3978.8 kPa right now, with your calculation. You are getting 3978.8 m2/s2 which is certainly not in units of pascals. You must pay attention to units.
If you're wondering why multiplying by the density seemingly doesn't change the numerical value of the answer, then consider this: what is the density of water in SI units? So, what numerical value would you be multiplying by?
What factor would you then divide the answer by to convert from Pa to kPa?
As far as the total density goes you have to take into account not only the pressure due to the weight of the column of water above the lake bottom, but also the pressure due the weight of the column of *air* above that.
In other words, the surface pressure is not 0.
yes, I just read through bpears answer more carefully, and realized it didn't make sense. By wishful thinking, it looks like he jumped past the step of multiplying by density.
Ok, so for number 2, density=mass/volume. I found the volume of a Liter of water is 1m^3. So, then I get 6kg/m^3. How does the book get 6000kg/m^3?
And for 3, I got the 1st part but I don't know how to get total pressure?
Because 1 L ≠ 1 m3. (One litre is NOT equal to one cubic metre).
This should be obvious, if you've ever seen a one-litre carton of milk, then you know that it is not as big as a cubical box that measures one metre on each side! Then again, maybe product volumes are typically given in imperial units where you live, in which case you might not have a good intuition for metric ones.
The thing I usually remember for converting this particular non-standard unit (the litre) is that
1 mL = 1 cm3.
Also, anticipating future questions you might have: you have to be careful when converting units of volume. It can be tricky. For example, you might naively think that 1 m3 = 100 cm3. This is FALSE. In fact:
1 m3 = (1 m)3 = (100 cm)3 = 100*100*100 cm3 = 1,000,000 cm3.
One cubic metre is a million cubic centimetres. That's an algebraic way to arrive at the answer. A geometric way to visualize this is that if you have a volume of 1 m3, that means you have a cube that is one metre on each side, i.e. its dimensions are (1 m) x (1 m) x (1 m). So the dimensions of this cube in centimetres is 100 cm on each side, or (100 cm) x (100 cm) x (100 cm), and the volume in cubic centimetres is this product, which works out to 1,000,000 cm3. In other words, if you have a small cube that is 1 cm on each side, then a million of these cubes, arranged in a 3D grid of 100 x 100 x 100, will fit inside a larger cube that is 1 m on each side.
  • · Replies 22 ·
  • · Replies 23 ·
