Help with Question C: Where to Start?
  • Thread starter cloud360
13 replies · 4K views · last reply
cloud360
I want to know how to answer question C
[PLAIN]http://img546.imageshack.us/img546/5682/maximumvaluek.gif
can someone tell me where to start a least so i can make an attempted solution. i have no idea where to start !
1) v2 has to be >= 0, being the square of a real number.
2) u2 < 2MG/a, which means that u2 - 2MG/a < 0.
In order for the right side to be >= 0, 2MG/r has to be more positive than u2 - 2MG/a is negative. IOW, 2MG/r must be > -(u2 - 2MG/a).
Does that get you started?
thanks for your reply, i am very grateful :)
but i think of v2 as (r')2, don't i have to solve a differential? v is not a constant?!? neither is r
NOTE: r'=r dot
Part c is what you asked about, and that doesn't involve solving a differential equation. Since you asked about part c, I assumed you had already done parts a and b.
For what I said earlier, it doesn't matter whether v or r are constants or not.
because the thing am confused about is that v^2=r'^2, and i was thinking i need to get r on one side, if so i need to solve the ODE?
if not, i am even more confused as my assumptions were dead wrong.
Would i get the correct answer if i assumed u^2=2MG/a then made the bracket =0, then solved to find r?
i still can't start this :(
hope this is not to much to ask of you, but can you tell me what i am supposed to aim for in this question, do i have to get r on its own on one side?
They're not asking you to solve this differential equation. Did you do part b? If so, you should have ended up with the equation they show in part b.
No, you can't assume that u2 = 2MG/a. They already told you that u2 < 2MG/a.
I don't know what "made the bracket = 0" means.
Reread what I said in post #2. I believe that's the direction you should take. I was able to get an upper bound on r from what I did.
so now should i solve
2MG/r > -(u2 - 2MG/a)?
still finding it difficult to start this question :(
i don't know what am supposed to solve or do to get max value of r.
i am certian max values are find by solving r'=0, they will give criticial points which are either min or max, this is how i have been always thought to find max and min
Solve this inequality for r.
See above.
See above.
1) ok, i got
r>-2MG/(u2 +2MG/a)
but then r'>0
what to do next
2) also why is it 2MG/r > -(u2 - 2MG/a).
why is it not 2MG/r > (u2 - 2MG/a),isnt that enough to solve r?
i understand that just being greater than a number i.e 2MG/r > (u2 - 2MG/a) won't make RHS positive it has to be 2MG/r > -(u - 2MG/a)
but why are you doing this i.e why are you making sure RHS is positive (i know that r'2>0, meaning RHS has to be positive and also >0), but why isn't 2MG/r > (u2 - 2MG/a), enough to solve r, its true isn't it?
3) also , why are you creating an inequality liek this while ignorign r'2. is it ok to ignore r'2
cloud360 said:
1) ok, i got
r>-2MG/(u2 +2MG/a)
That's incorrect. You have an incorrect sign somewhere, and you are supposed to show that r is less than some value.
cloud360 said:
but then r'>0
what to do next
It's given that u2 - 2MG/a < 0. The quantity on the left side, 2MG/r, is positive, so saying that 2MG/r is larger than some negative number doesn't help you get an upper bound on r.
The quantity -(u2 - 2MG/a) is positive. If we know that 2MG/r is larger than some positive number, we can use that information to say something about r.
So again, solve 2MG/r > -(u2 - 2MG/a) for r.
The answer is supposed to be an inequality, so you have to start with an inequality.
Yes, you can ignore r'. Part c is not about using r' to solve for r.
Ok i got (after multiplying top and bottom of RHS by a)
r<-(2aGM/(au^2-2Gm)
meaning r'<0, since a,u,G,M are constants?
but we don't need to find r' right? the answer is just r<-(2aGM/(au^2-2Gm) ?
(again i am so grateful to you, for your help)
r<-(2aGM/(au^2-2Gm)
A better way to write this is
r < 2aMG/(2MG - u2), but what you have is also correct.
I don't know how you conclude that r' < 0.
And right, this part doesn't ask you to find r by integrating r'.
so is the answer just the maximum is r=-(2aGM/(au^2-2Gm)
or do we have the differentate to get r', also are you saying r' is not <0, since if we differentiate RHS we should get 0, as all of RHS is constant?
Yes, but you should write this as rmax = 2aMG/(2MG - au^2)
Forget about r'. The equation rmax = 2aMG/(2MG - au^2) tells you the maximum possible value of r(t), which is different from what I'm calling rmax. Both sides are constants, so it would be useless to differentiate both sides.
I'm not saying anything about r'. I don't see anything in this problem that asks you to find r'.
