Help with second quantization practice problem
This discussion focuses on the application of second quantization in quantum mechanics, specifically demonstrating how the Hamiltonian operator, represented as $$\hat{H} = \Sigma_{ij} \langle i| \hat{T} | j \rangle \hat{a_i }^{\dagger} \hat{a_j}$$, interacts with the Heisenberg equation of motion. Participants clarify the steps to derive the equation $$\sum_{j} \langle k | \hat{T} | j \rangle \hat{a_j} = i \hbar \frac{d\hat{a_k}}{dt}$$, emphasizing the importance of commutation relations and orthonormality in simplifying expressions. Key points include the necessity to replace $$\hat{H}$$ with $$\hat{T}$$ in certain contexts and the proper treatment of derivatives in the equations.
  • Understanding of second quantization principles
  • Familiarity with the Heisenberg equation of motion
  • Knowledge of commutation relations in quantum mechanics
  • Proficiency in manipulating operator expressions and summations
  • Study the derivation of the Heisenberg equation of motion in quantum mechanics
  • Explore the implications of commutation relations in quantum field theory
  • Learn about the role of the Hamiltonian operator in quantum systems
  • Investigate the properties of orthonormal bases in quantum mechanics
Quantum physicists, graduate students in theoretical physics, and researchers working on quantum mechanics and quantum field theory will benefit from this discussion.
CMJ96
Moved from a technical forum, so homework template missing
Hi, to help further my understanding of the second quantization for one of my modules I would like to show that the following expressions
$$ \hat{H} = \Sigma_{ij} \langle i| \hat{T} | j \rangle \hat{a_i }^{\dagger} \hat{a_j} $$
$$\hat{\psi}(r,t)= \Sigma_k \psi_k(r) \hat{a}_k(t)$$
Obey the Heisenberg equation
$$i \hbar \frac{d\hat{a}_k}{dt}=\Sigma_j \langle k | \hat{T} |j \rangle \hat{a}_j$$
I started by subbing ##\hat{\psi}## and ##\hat{H}## into the Heisenberg equation of motion for a generic operator
$$ i \hbar \frac{\partial \hat{O}_H}{\partial t}= \left[\hat{O}_H,\hat{H} \right] $$
This gave me
$$\Sigma_k \psi_k(r) \hat{a}_k(t) \Sigma_{ij} \langle i | \hat{H} | j \rangle \hat{a}_i ^{\dagger} \hat{a}_j - \Sigma_{ij} \langle i | \hat{H} | j \rangle \hat{a}_i ^{\dagger} \hat{a}_j \Sigma_k \psi_k(r) \hat{a}_k(t)=\Sigma_k \psi_k (r) \frac{\partial \hat{a}_k (t)}{\partial t}$$
I canceled the ##\Sigma_k \psi_k(r) ## to give me the following but I'm not sure how to proceed after that
$$\ \hat{a}_k(t) \Sigma_{ij} \langle i | \hat{H} | j \rangle \hat{a}_i ^{\dagger} \hat{a}_j - \Sigma_{ij} \langle i | \hat{H} | j \rangle \hat{a}_i ^{\dagger} \hat{a}_j \hat{a}_k(t)= \frac{\partial \hat{a}_k (t)}{\partial t}$$
CMJ96 said:
This gave me
For reference, label this equation as (eq. 1).
(1) Should ##\hat{H}## be replaced by ##\hat{T}## in the two terms on the left of (eq. 1)?
(2) I believe a factor of ##i \hbar## is missing on the right side.
(3) You can replace the partial derivative with respect to ##t## on the right side by an ordinary derivative with respect to ##t## since ##\hat{a}_k(t)## is a function of a single variable, ##t##.
Call this (eq. 2).
To get to (eq. 2), you can't actually cancel ##\Sigma_k \psi_k(r) ## on both sides of (eq. 1). But you can get (eq. 2) by multiplying both sides of (eq. 1) by an arbitrarily chosen ##\psi_n^*(r)## and integrating over all ##r##. Using the orthonormality of the ##\psi_k(r)##'s, you will end up with (eq. 2) except your index ##k## in (eq. 2) would be ##n##. However, at that point, you could rename ##n## as ##k## and therefore have (eq. 2) as you wrote it. Maybe all of this is what you actually meant when you said that you "canceled the ##\Sigma_k \psi_k(r) ## ".
So, your (eq. 2) actually looks OK to me except for fixing up points (1), (2), and (3) that I listed in regard to (eq. 1).
Since the various ##\langle i | \hat{T} | j \rangle## 's are just numbers, you can move ##\hat{a}_k(t)## in the first term of (eq. 2) inside the summation to obtain
$$\ \Sigma_{ij} \langle i | \hat{T} | j \rangle \hat{a}_k \hat {a}_i ^{\dagger} \hat{a}_j - \Sigma_{ij} \langle i | \hat{T} | j \rangle \hat{a}_i ^{\dagger} \hat{a}_j \hat{a}_k= i \hbar \frac{d\hat{a}_k }{dt}$$
Now try to rearrange the order of the ##\hat a## operators in the first term so that they match the order of the operators in the second term. That is, try to move the operator ##\hat{a}_k## past the operators ##{a}_i ^{\dagger} \hat{a}_j## in the first term. You will need to invoke the commutation relations obeyed by these operators. See what you end up with.
Thank you for the help and I apologise for taking so long to reply
Your help was very useful, I used the commutation relation
$$\left[a_k,a_i ^{\dagger} \right] = a_k a_i ^{\dagger} - a_i ^{\dagger} a_k = \delta_{ki} $$
Rearranging this and replacing ##a_k a_i ^{\dagger} ## (and using the identity ##\langle i | j \rangle =\delta_{ij}## ) I ended up with the following
$$\sum_{ij} \langle i | T | j \rangle \langle k | i \rangle a_j + \sum_{ij} \langle i | T | j \rangle a_i ^{\dagger} a_k a_j - \sum_{ij} \langle i | T | j \rangle a_i ^{\dagger} a_j a_k = i \hbar \frac{d a_k}{dt}$$
The last two terms on the left hand side cancel off as ##a_j## and ##a_k## commute and since ##\langle i | i \rangle =1## the first term becomes what I was looking for
Thank you!
OK. Personally, I wouldn't bother to bring in the identity ##\langle i | j \rangle =\delta_{ij}##. From the commutation relation, we have ##\ a_k a_i ^{\dagger} = a_i ^{\dagger} a_k + \delta_{ki} ##. Using this yields $$\sum_{ij} \langle i | T | j \rangle \delta_{ki}a_j+ \sum_{ij} \langle i | T | j \rangle a_i ^{\dagger} a_k a_j - \sum_{ij} \langle i | T | j \rangle a_i ^{\dagger} a_j a_k = i \hbar \frac{d a_k}{dt}$$The first term then reduces immediately to $$\sum_j \langle k| T | j \rangle a_j$$
This is a more concise way of doing it, how exactly does it immediately reduce?
When summing over ##i## in ##\sum_{ij} \langle i | T | j \rangle \delta_{ki}a_j##, the only value of ##i## that will contribute is when ##i = k##, due to the Kronecker delta ## \delta_{ki}##.
Ahhh yes, I understand now, thank you very much, you have been very helpful
  • · Replies 0 ·
