Hermiticity and expectation value
The discussion revolves around the concept of hermiticity in quantum mechanics, specifically exploring methods to verify whether certain operator combinations are hermitian without resorting to expectation values. The participants also delve into properties of operators and the challenges associated with unbounded operators.
  • One participant questions the effectiveness of using expectation values to check for hermiticity, suggesting that alternative methods might exist for combinations like xp - px or pxp.
  • Another participant presents a mathematical property regarding the adjoint of a product of operators, stating that (AB)^\dagger = B^\dagger A^\dagger.
  • A participant expresses uncertainty about the derivation of the adjoint property and seeks clarification on its acceptance as a property.
  • A mathematical expression is provided to demonstrate that (AB)^\dagger = B^\dagger A^\dagger by using the definition of inner products.
  • Concerns are raised about the validity of certain statements regarding operators, particularly emphasizing that the property mentioned is valid only for bounded operators, while the operators in question (x and p_x) are unbounded.
  • Another participant argues that the property is sufficiently valid in the context of checking for hermiticity, as hermitian operators are symmetric and bounded, and expresses a desire for a rigorous proof of the property (A+B)^{\dagger} = A^{\dagger}+B^{\dagger}.
Participants express differing views on the applicability of certain properties to unbounded operators, and there is no consensus on the need for rigorous proofs of these properties. The discussion remains unresolved regarding the best methods to check for hermiticity.
Participants note limitations regarding the assumptions about bounded versus unbounded operators and the need for careful consideration in applying certain properties.
holden
is there a better way to check for hermicity than doing expecation values? for example, what if you had xp (operators) - px (operators), or pxp (operators again); how can you tell if these combos are hermetian or not, without going through the clumsy integration (that doesn't give a solid result, as far as i can tell)? thanks.
[tex](AB+CD)^\dagger = B^\dagger A^\dagger + D^\dagger C^\dagger[/tex]
heh, thanks. i suck.
although, actually, i still have a question.. where does that come from, is it just an accepted property? i can't seem to derive it or find a place where it has been derived.
[tex]\left< (AB)x,y \right> = \left< A(Bx),y \right> = \left< Bx, A^\dagger y \right> = \left< x, (B^\dagger A^\dagger) y \right>[/tex]
By definition, this shows that [tex](AB)^\dagger=B^\dagger A^\dagger[/tex].
What Euclid wrote is valid only for bounded operators. The "x" and "p_x" operators are unbounded, so care is needed in order not to write some garbage.
Daniel.
However, in the context of what holden wrote, what Euclid stated is valid enough, because holden wants to check for hermicity and hermitian operators are symmetric and bounded.
On the other note, I want to see a somewhat rigorous proof that
[tex]\left(A+B\right)^{\dagger} = A^{\dagger}+B^{\dagger}[/tex]
All the sources say this property, but they don't bother proving it.
  • · Replies 20 ·
  • · Replies 25 ·
