Hi,I was wondering if acceleration was a form of nonuniform speed?
The discussion revolves around the relationship between acceleration and speed, specifically whether acceleration can be considered a form of nonuniform speed. Participants explore the definitions and implications of speed and velocity in the context of acceleration, including scenarios involving uniform speed and changes in direction.
  • Some participants assert that acceleration is synonymous with nonuniform speed.
  • Others clarify that acceleration refers to nonuniform velocity, and an object can maintain uniform speed while still accelerating if it follows a curved path.
  • A participant acknowledges a misunderstanding and agrees that nonuniform speed is an example of acceleration.
  • There is a discussion about the relationship between speed and direction, with some arguing that changing direction involves a decrease in speed in one dimension and an increase in another, suggesting this is fundamentally non-uniform speed.
  • Another participant counters that speed, being the magnitude of velocity, is directionally independent, and thus acceleration cannot simply be termed nonuniform speed without considering velocity.
  • Concerns are raised about the potential confusion arising from mixing the concepts of speed and velocity, particularly in the context of uniform total speed while accelerating.
  • One participant emphasizes the importance of using technical definitions in physics discussions, indicating that informal language can lead to misunderstandings.
Participants express differing views on the definitions and relationships between acceleration, speed, and velocity. No consensus is reached, and the discussion remains unresolved regarding the precise nature of these concepts.
There are limitations in the discussion regarding the definitions of speed and velocity, as well as the implications of directionality in the context of acceleration. Some assumptions about the relationships between these terms are not fully explored or agreed upon.
Bashyboy
Hi,
That's what it means!
Well, thank you very much for answering so promptly.
Well...
Acceleration means nonuniform velocity. An object can have a uniform speed and still be accelerating (if it is following a curved path at a constant speed).
I said it the wrong way round; non-uniform speed is called / is an example of acceleration.
You are right about change of direction, of course. Mea culpa for being so sloppy.
cjl said:
Well...
Changing your direction is actually just a decrease in speed in one orthogonal dimension and an increase in another however, so fundamentally it is non-uniform speed.
Since speed is the magnitude of velocity, that isn't really the case.
Total speed is the magnitude of velocity. Acceleration is non-uniform speed in at least 1 spatial direction.
You're trying to invoke direction, but by definition, speed is directionally independent. If you include directional information, you're talking about velocity, not speed.
I was commenting on your remark that acceleration means nonuniform velocity. And that you can have a uniform speed and still be accelerating. What you mean is that you can have a uniform "total" speed in all directions and still be accelerating. This makes it much more confusing than it actually is and people get confused as to why changing direction is acceleration, it makes it sound mysterious when it is not.
You can't say that your speed is uniform because you are making up for a loss in speed in one orthogonal direction by a gain in speed in another orthogonal direction. This is why they are "orthogonal".
When you go around a turn in your car you are reducing your speed in the direction you were travelling, this is why you feel the same effect as if you press on your brake.
This is a physics board and we are using the word "speed" in its technical, physics, meaning. Talking about "speed in the direction you were travelling" indicates that you are not.
  • · Replies 22 ·
  • · Replies 68 ·
9K
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 24 ·
