What Does the Shape of the Higgs Potential Tell Us?
  • Context: Undergrad
  • Thread starter Thread starter kelly0303
    Higgs Potential Shape
This discussion centers on the interpretation of the Higgs potential in the context of a real scalar field, specifically its graphical representation resembling a "Mexican hat." The potential, denoted as ##V(\phi)##, is plotted against the field ##\phi##, which is not an independent variable but rather a function of spacetime coordinates. Participants clarify that for the purpose of analyzing the vacuum state, the field is assumed to be constant, allowing for the identification of minima in the potential. The conversation emphasizes the importance of understanding the implications of field constancy in relation to spontaneous symmetry breaking and the kinetic terms of the field.
  • Understanding of scalar fields in quantum field theory
  • Familiarity with the concept of spontaneous symmetry breaking
  • Knowledge of potential energy functions in physics
  • Basic grasp of gauge invariance and its implications
  • Explore the mathematical formulation of the Higgs potential in quantum field theory
  • Study the implications of gauge invariance on field configurations
  • Investigate the role of kinetic terms in scalar field theories
  • Learn about the physical significance of vacuum states in quantum mechanics
Physicists, particularly those specializing in quantum field theory, students studying particle physics, and researchers interested in the properties of the Higgs field and spontaneous symmetry breaking.
kelly0303
Hello! I am going to talk here about a real scalar field for simplicity. If we have a Higgs-like potential for a real scalar field, the graph of the potential looks like a section of a "Mexican hat", with a bump at 0 and two absolute minima at, say, ##\pm a##. This is the plot I see in any book talking about spontaneous symmetry breaking. Although I understand how the symmetry is broken I am a bit confused about the graph itself (the actual picture of it). The graph has on the y-axis the potential ##V(\phi)## and on the x-axis the field ##\phi##. I am not sure how to think about the x-axis, as the field is not an independent variable, it depends on the space-time variables i.e. ##\phi = \phi(x,y,z,t)##. So if I read on the graph that ##V(a)## is a minimum, this means means that when the value of the field is ##\phi(x,y,z,t)=a##, the potential reaches a minimum. But what does it mean that ##\phi(x,y,z,t)=a##? The field doesn't take a single value. One can have ##\phi(2,7,\pi,12.4)=a## but ##\phi(e,22,0,12.4)=7*a+25##. Do we assume for this plot that the field is constant everywhere? And if so, why do we do this? The field has a kinetic term, so it can have change in time. Do we do it because we want to see the actual minimum value of the vacuum and hence, as we need minimum energy, we set it constant just to discard the kinetic term? Thank you!
If you want it to have the minimal energy configuration, it does.
The potential (density) V is a function of the field value. If you want to plot it, then it makes sense to plot it as a function of the field value. Even if you have a field configuration which is not the global minimum, your potential density at an event only depends on the field value at that event (of course, the potential density may then be different at different spacetime events, but this is not the issue here).
Yes. The kinetic terms are non-negative and will be zero when the field is constant. The mimimal energy is therefore obtained for a constant field at the bottom of the potential density.
Field which isn't constant everywhere means you have "particles" of this field (perturbations of the field). When you look for a vacuum state, of course this shouldn't be the case.
Therefore, yes, you assume that the field does take the same value everywhere in the vacuum. Modulo gauge invariance: field can have seemingly different values at different points, but if they can be made to be the same value everywhere via a gauge transformation, then it's not a state with particles.
The Higgs field cannot be a constant
First of all, this thread is two months old. Second, we are discussing the ground state of the Higgs field. Third, the Higgs vacuum does correspond to a state where the Higgs field is constant.
Perhaps you would like to qualify your statement further?
  • · Replies 30 ·
