rakeshkv
- 2
- 0
can anyone explain about high speed semiconductors . how do ge and gaAs can achive those speeds
marlon said:Ok, but there IS a reason why Si is used in transistors and NOT Ge. Ge has prospects to replace Si as the CMOS substrate but lots of work needs to be done.
These caracteristics of Ge itself are not really that important when it comes to CMOS devices. The key parameter is the electrical quality of the interface between Ge and the dielectric that you use (like HfO2 or HfSiO4 in today's research). The contact of Ge and the dielectric will cause the Ge to oxidize and there is your "problem" : the interface does not have the right electron affinities for CMOS operation. Due to the oxidation at the interface, the Ge electron affinity will change when you are close to the interfacial region between Ge and the high k material. Incorrect electron affinities lead to a flatband voltage shift that causes the CMOS transistor to slow down and become more energy consuming (bigger leakage currents). Also, one needs to study the influence of dopants (C,N) and oxidation (especially due to the high k deposition method like Atomic Layer Deposition) onto the interface electrostatics. I have a friend at IMEC who is working on this.
marlon
Hans de Vries said:This is a very interesting area of research. One might wonder if an ALD
processed ultra shallow layer of Si between the Ge channel and the
dielectric could do the trick. The big advantage would be compatibility
with all the work done one high-k dielectrics and metal gates.
marlon said:Besides, you wouldn't want to bring in a Si layer between Ge and the dielectric for several reasons :
1) electron mobility of Si lower as Ge
2) how to control the interface electrostatics with an additional layer in the stack
3) the presence of an extra capacitance that lowers the CMOS switching speed (this is a detrimental effect that you also have with the polysilicon gate ontop of the SiO2 dielectric)
4) The ALD process is very accurate with respect to obtaining the correct dielectric thickness after "enough" cycles. But ALD is not used to deposit just Si because there is always going to be oxidation due to the H20 presence.
5) H20 is very polar and also has an influence on the interface electrostatics. The same problem occurs at the metal gate/high k interface.
marlon
Hans de Vries said:I'm aware of the first 3 points, they are pretty elementary, 1 and 3
should go away if the interface layer is in the order of a few atoms.
I know.Important is a very smooth interface since any scattering here gives
you performance loss.
I know that and i am not objecting against that. I am objecting against your idea that you put in a Si ALD deposited layer to mimic the classic Si substrate.The point is, as usual, people want to work with what they've got.
When the high-k /metal gate combination works you want to re-use
it for SiGe or pure Ge channels.
Nitridation of the gate dielectric is already used and successful (ie with right CV curves) CMOS devices have already been constructed.High k gates won't get used now at initial processes for the 45 nm node
because of the problems there still are with finding the right gate metals,
(different ones for n- and p- type Fet's )
Indeed, but this phenomenon also occurs in the metal gate high k gate stack.As far as I
know polysilicon gates were given up because of Fermi level pinning.
