Highest harmonic in closed pipe with 45cm length
9 replies · 15K views
TFM
[SOLVED] Open ended pipe Harmonics Mastering Physics Question
Consider a pipe 45.0cm long if the pipe is open at both ends. Use v = 344m/s.
Now pipe is closed at one end.
What is the number of the highest harmonic that may be heard by a person who can hear frequencies from 20 Hz to 20000 Hz?
[tex]f_n = (2n-1)\frac{v}{4L}[/tex]
I have an answer that works, but masteringphysics doesn't accept. I first rearranged the equation to give me:
[tex](2n-1) = \frac{f_n * 4L}{v}[/tex]
then:
[tex]2n = (\frac{f_n * 4L}{v})+1[/tex]
and finally:
[tex]n = ((\frac{f_n * 4L}{v})+1)/2[/tex]
inserting the values gives 52.5 so I inserted 52 as the answer. wrong, I have tried 51-54, all wrong. so I thought tpo go backwards, using:
and inserting values, to find the value which is the closest to 20000, buit under it - guess what, the value that came out:
52!
Any ideas
TFM
The harmonics of a pipe closed at one end are all odd. For n = 2 you have the 3rd harmonic. For n=52 what harmonic do you have?
It will be the 53rd Harmonic. The trouble is, I have put 53 in, and it says its the wrong answer!
Sorry that third harmonic was a bad example. The harmonics are given by 2n-1. So if n is 52 what is the harmonic. An easier way to have thought about it would to have solved for:
[tex]f_n = \frac{nv}{4L}[/tex]
for n = 1, 3, 5,...
Using:
and using n = 103,
I get a frequency of 19684, which is the first odd number below 20000. would this be the harmonic number?
TFM
TFM
Yes n is the harmonic number.
Success! n = 103.
IOne thing does bother me slightly - where does my orginal answer of 52 fit in?
TFM
2n - 1 is just another way of saying n = 1, 3, 5, ... . So if you stick n = 52 into 2n - 1 you get 103.
That makes sense.
Thanks,
TFM
TFM said:
That makes sense.
Thanks,
TFM
What I was originally aiming at was for you to put the n = 52 into that equation and get 103 but I used a stupid example which probably mislead you slightly. :smile:
