What Is the Final Speed After Two Hockey Players Collide?
  • Thread starter Thread starter Precursor
    Momentum
The final speed after two hockey players, each weighing 72.0 kg and skating at 5.45 m/s, collide and stick together at an angle of 115 degrees is calculated to be 2.93 m/s. The momentum conservation equations used include p = mv and p_{i} = p_{f}. The initial momentum components were adjusted using the sine function for the angle of 57.5 degrees, leading to the correct calculation of the final velocity.
  • Understanding of momentum conservation principles
  • Knowledge of vector components in physics
  • Familiarity with trigonometric functions, specifically sine and cosine
  • Basic algebra for solving equations
  • Study the principles of momentum conservation in collisions
  • Learn how to resolve vectors into components
  • Explore the application of trigonometric functions in physics problems
  • Practice solving collision problems with varying angles and masses
Students studying physics, particularly those focusing on mechanics and collision problems, as well as educators looking for examples of momentum conservation in real-world scenarios.
Precursor
Two 72.0 kg hockey players skating at 5.45 m/s collide and stick together. If the angle between their initial directions was 115^{o}, what is their speed after the collision?
p = mv
p_{i} = p_{f}
Here's my interpretation of the image;
http://img696.imageshack.us/img696/1493/momentum.png
p_{ix} = p_{fx} = 0
p_{iy} = p_{fy}
m_{A}v_{A} + m_{B}v_{B} = (m_{AB})(v_{AB})
(72)(5.45cos(32.5)) + (72)(5.45cos(32.5)) = 144v_{AB}
v_{AB} = 4.60 m/s
Am I correct?
P*cosθ components of the two players get canceled according to the diagram given by you . Check the other components. Your calculation will be correct if you use θ = 57.5 degrees.
Oh, so I need to use sin instead?
For your mentioned angle, yes.
Ok, so the new answer is 2.93 m/s.
Thanks for the help
12K
