What is the thickness of the wall of a hollow iron sphere submerged in water?
  • Thread starter Thread starter kristjan
    Sphere Water
The thickness of the wall of a hollow iron sphere submerged in water, with an outer diameter of 10 cm and iron density of 7.9 g/m³, is calculated to be 0.11 cm. The buoyant force was determined using the formula F=ρgV/2, where ρ is the density of water and V is the volume of the sphere. The mass of the sphere was found to be 0.26 kg, leading to the conclusion that the volume of the wall is derived from the difference between the outer and inner sphere volumes. The discrepancy with the book's answer of 0.22 cm is attributed to an error in the exercise's re-writing.
  • Understanding of buoyant force calculations
  • Knowledge of density and volume relationships
  • Familiarity with the properties of hollow spheres
  • Basic algebra for solving equations
  • Study the principles of buoyancy in fluid mechanics
  • Learn about the calculation of volumes for different geometric shapes
  • Explore the properties of materials, focusing on density and its applications
  • Investigate common errors in physics problem-solving and how to avoid them
Students studying physics, particularly those focusing on fluid mechanics and material properties, as well as educators looking for examples of buoyancy and density calculations.
kristjan
Hollow iron sphere is half submerged in water.Sphere has outer diameter of 10 cm. Calculate thickness of the wall , when the iron density is 7.9 g / m3.
I get answer 0.11cm, book says that it is 0.22cm.
[/B]
First i found buoyant force F=ρgV/2 where ρ is density of water and V is volume of a sphere.
Then I found mass of a sphere : ρgV/2=mg
m=0.26 kg
I know density of iron ,so: 7900=0.26/v where v is volume of the wall
(v= volume of outside sphere - volume of inside sphere.)
From there I get thikness of the wall to be 0.11cm.
Your method looks correct. I agree with your answer of .11 cm.
Someone made my "intuitive" error while re-writing the exercise for the "n-th" edition; agreed, 0.11 cm.
  • · Replies 16 ·
  • · Replies 21 ·
15K
