What is the kernel of the determinant mapping in GL(2,R)?
  • Thread starter Thread starter Benzoate
    Homomorphisms
The kernel of the determinant mapping from GL(2,R) to R* is identified as SL(2,R), which consists of 2x2 matrices with a determinant of 1. The determinant mapping is a homomorphism, meaning it preserves the group structure, specifically the identity element in R*. The discussion clarifies that the kernel is the set of matrices that map to the identity element of the codomain, not zero, emphasizing the distinction between group and ring identities.
  • Understanding of group theory, specifically homomorphisms and kernels.
  • Familiarity with the definitions of GL(2,R) and SL(2,R).
  • Knowledge of determinant properties in linear algebra.
  • Basic concepts of identity elements in groups and rings.
  • Study the properties of group homomorphisms in detail.
  • Learn about the structure and significance of SL(2,R) as a subgroup of GL(2,R).
  • Explore the implications of the determinant mapping in higher dimensions, such as GL(n,R) and SL(n,R).
  • Investigate the role of identity elements in various algebraic structures, including groups and rings.
Mathematicians, particularly those studying abstract algebra, linear algebra, and group theory, will benefit from this discussion, as well as students tackling advanced topics in these fields.
Benzoate
Let R* be the group of nonzero real numbersunder multiplications. Then the determinant mapping A->det A is a homomorphism from GL(2,R) to R* . The kernel of the determinant mapping is SL(2,R).
I know det(A)det(B)=det(AB) but other than knowing that property, I don't understand the meaning of the kernel nor SL(2,R) nor do I understand how GL(2,R) is a homomorphism. I know SL(2,R) stands for Special linear group and GL(2,R) General Linear group.
GL(2,R) isn't a homomorphism. It is a group. Your post clearly states that the determinant map is a homomorphism, not GL(n,R).
What is det(I), I the identity?
Doesn't this show that det satisfies the definition of homomorphism?
You do understand what SL(2,R) is - you wrote out its definition: the set of matrices of determinant 1.
The kernel is the set of matrices sent to the identity...
Isn't the kernel the set of stuff that is sent to 0, not the identity?
Groups aren't even required to have an element called '0'!
Yeah true, so the definition I had must've been for something with identity=0. So is it really what is sent to the identity?
In a group, the identity is often denoted e. The zero is the additive identity element in a ring. The wikipedia article calls the identity element (in a group) 1.
So, calling the additive identity either 0 or 1 is generally a bad idea. (the '1' is actually 0 in the group of integers and all of its subgroups, and calling it '0' is...a ring thing)
The kernel of a group homomorphism phi:A->B is the preimage of {e_B} under phi, e_B the identity element in e_B. The preimage of a subset S of B under a function f:A->B is defined set theoretically as {x in A : f(x) in S}.
So for your problem: What's the identity element in R*? (Certainly not zero!) What's the preimage of this identity under the group homomorphism given by the determinant?
These should all be obvious to you.
(Note: SL(n,R) is defined as the nxn matrices over R with determinant 1. Exercise: Show that this is a subgroup of GL(n,R))
  • · Replies 36 ·
