Homomorphisms from Q/Z to Z
  • Thread starter Thread starter TheForumLord
12 replies · 2K views
TheForumLord
The last parts of the problems were:
1. prove that for each natural n, the additive quotient group Q/Z contains a one and only subgroup of order n and that sub-group is cyclic.
2. let G,H be two finite sub-groups of Q/Z. prove that G is contained in H if and only if
o(G)|o(H).
3. find all homomorphisms from Z/nZ to Q/Z.
but I've no clue how to start with the 4th part:
4. find all homomorphisms from Q/Z to Z...
TNX for all the helpers...
none.
none...
For number 4, consider a nonzero element of Q/Z. You can represent it by a rational n/m with n and m integers. If you add n/m to itself m times, you get 0 in Q/Z. What does that tell you about the image of n/m under the homomorphism?
For the first one, try finding a more familiar group that's isomorphic to Q/Z (hint: think complex)
Let n/m+Z be a nonzero element of the quo. group. the order of this element if m (if we assume that gcd (n,m)=1) . the image of n/m under the homo. has to be an element in Z of order m. But in Z, which element has order m?? how come this is the only homo. possible?
Help is needed :(
TNX !
If phi is your homomorphism, it doesn't really say phi(n/m) has order m. It says phi(n/m)*m=0. The only integer satisfying that is 0. So phi(n/m)=0, for all elements of Q/Z. That's why it's the only homomorphism possible.
so the homo is:
each and every element in Q/Z goes to 0?
TNX
TheForumLord said:
so the homo is:
TNX
What else could it be?
right...Tnx a lot! Hope you'll be able to help me in my next thread too...
Can you please give me directions about the 3rd one?I
I'm pretty lame in all the Homomorphism theorems...
TNX again
Just start thinking about it. If you know what the image of the element '1' in Z/nZ is, then you know the rest of the homomorphism. What are the possibilities?
The image of "1" in Z/nZ (which is of course "n" or "0" ) can be each and every one of the generators of the sub-groups from order n...I've proved that there's only one sub-group of order n in Q/Z and it's cyclic...Each one of it's generators are from the form i/n... Am I on the right track?
TNX a lot!
Z/nZ={0,1,2,...n-1}. '1' doesn't mean 0 or n. It means 1. But yes, every element of Z/nZ has order n, so the image of an element i under the homomorphism has to satisfy phi(i)*n=0 in Q/Z. That makes it one of the i/n, sure.
