Hooks Law F = kx Book answer wrong I think
  • Thread starter Thread starter Barclay
    Book Law
8 replies · 3K views · last reply
Barclay
[/B]
Hello, two basic questions on the same topic and I think the book answer is wrong so I've posted both here if that's okay.
Q1. What force is required to stretch a spring with spring constant 0.2 N/cm a distance of 5 cm?
Q2. A vertical spring stretches 5 cm under a load of 100 g. Determine the spring constant.
2. Homework Equations
F = kx k = spring contant x = extension in spring
Q1. F = kx
F = 0.2 x 5
F = 1 N
1 Newton is my answer but the book says 0.01 N.
Q2. 100g = 0.1kg therefore weight (force) = 0.1 x 10 = 1 N
F = kx
1 = 5k
k = 0.2 N/cm
0.2 N/cm is my answer but the book says 0.05 N/cm. I can't see where I've gone wrong. Please advise.
Are you sure the dimension of the spring constant is N/cm and not N/m?
The solution in the book seems to be the inversed value of the spring constant, again using the common dimension N/m for it.
Yes absolutely sure
Barclay said:
Yes absolutely sure
Your calculations seem to be correct to me.
Q1:
If you take k = 0.2 N/m, then
F = 0.2 N/m ⋅ 0.05 m = 0.01 N
Q2:
If you take k in N/m, then
k = 1 N / 0.05 m = 20 N/m → 1/k = 0.05 m/N
Maybe this is where the answers are coming from, but they have to have messed up several times.
1 Newton is equal to 1 kg m/s2. The cm and m cannot cancel each other out. Change the cm to m first, then solve.
Barclay said:
Q1: 1 Newton is my answer but the book says 0.01 N.
1N is correct unless somebody meant k = 0.2N/m.
Q2: 0.2 N/cm is my answer but the book says 0.05 N/cm.
The book here is wrong no matter what. Your answer is correct.
Thanks all. The book authors were trying to explain (somewhere earlier in the text) that the "spring constant can be in N/cm or N/mm as long as the extension is measured in the same units". So I think the authors go mixed up with all the units somewhere because they've been working in metres up to that point in the book
I just read this and seems to make sense.
So for Q1 What force is required to stretch a spring with spring constant 0.2 N/cm a distance of 5 cm?
0.2N/cm = 20N/m
5 cm = 0.05 m
F = kx
F = 20 x 0.05
F = 1 N
So the same answer as mine. This book is just wrong.
Ya. get a new book!
