Horizontal Asymptote by Long Division?
The discussion focuses on finding the horizontal asymptote of the function \( f(x) = \frac{2x^2 + 5x - 3}{x^2 - 2x} \). Two methods are presented: long division, which yields \( 2 + \frac{9x-3}{x^2-2x} \), and a simplified approach that directly identifies \( 2 \) as the horizontal asymptote by removing lower degree terms. Both methods are valid, but the second method is preferred for its simplicity. The limit concept, specifically \( \lim_{x \to \infty} \frac{1}{x^n} = 0 \) for \( n \geq 1 \), is crucial for understanding why the fractional part approaches zero.
  • Understanding of horizontal asymptotes in rational functions
  • Familiarity with polynomial long division
  • Knowledge of limits in calculus
  • Ability to simplify rational expressions
  • Study the concept of horizontal asymptotes in rational functions
  • Learn polynomial long division techniques in detail
  • Explore limit properties, particularly \( \lim_{x \to \infty} \) behavior
  • Practice simplifying rational expressions to identify asymptotic behavior
Students studying calculus, particularly those focusing on limits and asymptotic analysis, as well as educators looking for effective methods to teach these concepts.
Painguy
Find the horizontal asymptote
There are two ways I did this problem. One way seems to be a coincidence and the other the "proper way"
1. I used long division, and got 2+(9x-3)/(x^2-2x)
2 seems to be the horizontal asymptote of the function
2.If we remove the highest degree terms from the function you end up with (2+(5/x) -(3/x))/(-2/x) with 2 being the horizontal asymptote.
Which is the proper method and why is it that everything I've ran into so far displays this.
Both are correct methods, but you would probably choose to do the second method because it's easier (unless the question specifically asked for you to solve it with method 1.).
Do you understand why method 2. works? Also, you shouldn't be saying method 1. has an asymptote of 2 because it seems to be, you need to give a better reason than that!
Notice it's nearly the same as method 2. Can you show that the fractional part in method 1. has an asymptote of 0?
Either way is fine. In the first case, you got
$$f(x)=\frac{2x^2+5x-3}{x^2-2x} = 2 + \frac{9x-3}{x^2-2x}.$$ If y=2 is the asymptote, that means the fractional term goes to 0 as x goes to ±∞. Do you understand why that's true?
In the second case, it looks like you have a few typos and meant
$$f(x) = \frac{2x^2+5x-3}{x^2-2x} = \frac{2 + \frac{5}{x} - \frac{3}{x^2}}{1-\frac{2}{x}}.$$ (If they weren't typos, you're not doing it right and need to figure that out.) When x grows large, the terms with x in the denominator become small, and you find f(x) approaches 2.
The second method is the one you'd use more often because long division is a pain.
Thanks guys, and yes I understand why the second method works. It's a limit related thing...right? :-p
Yes, \lim_{x → ∞} \frac{1}{x^n} = 0\,\, \forall\,\, n ≥ 1
  • · Replies 18 ·
  • · Replies 20 ·
