How Are USB Ports Waterproofed in Mobile Devices?
  • Thread starter Thread starter raminee
The discussion revolves around the methods used to waterproof USB ports in mobile devices, particularly in the context of wearable technology for children. Participants explore various protective measures against water damage and electrical shorting when devices are exposed to moisture.
  • One participant inquires about the protection mechanisms for USB ports against water damage in mobile devices.
  • Another participant notes that standard USB connectors are not designed for wet environments and mentions a moisture sensor in their device that triggers an error when moisture is detected.
  • A participant shares their intention to develop a wearable product for kids that requires USB connectivity, expressing concern about potential water exposure.
  • Suggestions include researching waterproof USB ports and considering alternative connectivity options like Bluetooth and wireless charging to avoid the complexities of waterproofing USB connectors.
  • One participant mentions existing methods such as using covers for USB ports and diodes on power lines, while seeking additional techniques.
  • Another participant describes a magnetic charging solution with spring pins as a simpler alternative to waterproofing traditional connectors.
  • A participant shares an experience with a waterproof device that uses a rubber seal for port access, emphasizing the importance of proper sealing to prevent leaks.
Participants express a range of views on the feasibility and effectiveness of waterproofing USB ports, with no consensus reached on the best approach. Some advocate for alternative solutions, while others focus on traditional methods.
Participants mention various techniques and experiences, but there are unresolved questions about the effectiveness and practicality of different waterproofing methods. The discussion includes assumptions about the reliability of certain technologies and the potential costs associated with different solutions.
This discussion may be of interest to developers of wearable technology, engineers focusing on device durability, and individuals exploring waterproofing solutions for electronic devices.
raminee
TL;DR
How to water proof a USB port?
Hello All,
I would like to know how mobile devices or EE devices that use mini/micro USB ports are protected from any water contacts ?
i.e. how can you protect against any electrical shorting/damages when such devices are immersed in water ?
R.
USB connectors are not meant for use in water, AFAIK. In fact, my Google Pixel 6 cellphone has a moisture sensor in its USB-C connector that throws an error if the "moisture content" gets too high. (that happened one time when I was working out in the rain for a while)
Why do you want to use standard USB connectors in wet environments? What is the application?
I am actually trying to build a wearable product for kids which has a USB connection for charging as well as data connectivity just like many wearable/mobile devices.
We envision that kids are not careful enough and may accidentally get the device wet through rain, just like your own experience, or jump in a pool of water etc and hence I was curious to know how the USB port is protected from water contacting it. I see a lot of iPhones that are recovered from waters such as rivers and they still work well.
With the PCB portion there are water protection resins that one can coat them with but I was not sure how the USB pins get protected as these would have to be uncovered for connectivity with a male USB pin.
Thank you "Berkeman" !
I already did some research and the two methods that I came across is a cover for the USB and also putting a diode between the power lines on the USB lines. But I was wondering if there are other techniques that they use.
We do have BTLE but adding a wireless charger and a cradle just adds to the cost and complexity of the system. Maybe version 2 !
Cheers
R.
A ready-made wireless charge receiver instead of reliably waterproofing a connector which is not intended to be waterproof may be significantly cheaper and simpler.
Look up 'QI wireless charging receiver'.
A solution that I have seen on a step tracking watch is that they have metallic spots on the case and use a magnetic cradle with spring pins. Sealing two small pins into a case is way easier than sealing an actual connector system.
The charger for that device is not smart. It burned up when it attracted a paperclip and shorted. Look up how Power Over Ethernet negotiates power to make a safer charger.
BoB
My Kobo reader is waterproof. I know, I have pics of me reading it in a pool in Cuba.
It has a watertight rubber seal that you have to pull off to access the port. But if you don't fit it back on, it will surely leak.
