How can I accurately simulate projectile motion with variable factors?
The discussion focuses on accurately simulating projectile motion with variable factors, particularly in scenarios involving drag, release height, and different launch conditions. Participants explore both theoretical and numerical approaches to modeling these dynamics, considering factors such as terminal velocity and release angles.
  • One participant expresses difficulty in finding suitable equations for projectile motion launched from a height, particularly with variables like release angle, velocity, and drag.
  • Another participant suggests that solving 2-dimensional projectile motion with drag analytically is not feasible and recommends numerical methods for simulation.
  • A different participant notes that while horizontal and vertical motions can be treated independently in the absence of drag, incorporating drag complicates the analysis, necessitating numerical methods.
  • Discussion includes the consideration of different models for drag force, with one participant referencing a resource on drag physics.
  • One participant mentions that if drag is proportional to the square of the velocity, an exact solution exists due to the nature of Bernoulli differential equations, but acknowledges that more complex drag models may not yield nice solutions.
  • A participant indicates their intention to build a Java application for simulation and requests examples of equations using piecewise linear and Bernoulli differential equations.
  • Another participant describes the standard numerical simulation method using Euler's method, detailing how to update position and velocity at each time step based on Newton's laws.
Participants generally agree that numerical methods are necessary for simulating projectile motion with drag, but there is no consensus on the best approach or model to use, as various methods and complexities are discussed.
Participants mention limitations related to the complexity of drag models and the challenges of achieving closed-form solutions, indicating that assumptions about drag force can significantly impact the analysis.
geekyhawkes
I have been looking into projectile motion equations and am struggling to find suitable ones that cover a projectile being launched at height. I know this sounds like homework, but it isn't. I am after trying to understand a 6 degree of freedom style taking into account terminal velocity, terminal angle etc.
I guess to help the discussion an example would be sensible;
Take an object carried by a bird in its feet. Variables I see assuming the bird is on Earth are;
Release angle from the birds flight path
Release velocity
Object drag
Release height above ground
I guess moving forward the things to consider would also be, what if the bird were climbing at the time of release, or in a dive.
Thanks for any help with this, I have found a lot of ballistic calculations for rockets, but none that allow for horizontal flight, terminal velocity etc.
Andy
I don't think it's possible to solve 2-dimensional projectile motion with drag analytically to get closed-form equations. I've only done such problems by calculating the path over a series of short time steps, using some method for solving a system of coupled differential equations numerically in a computer program or on a spreadsheet.
You seem to have two issues here. The first is that you want to work in two dimensions. This it easy enough if you consider horizontal and vertical motions independently. It's particularly easy in the absence of air drag and there are simple formulae (suvat) to help you.
The other issue is drag. As jtbell says, there are no analytic methods to deal with the addition of drag but it is really not too hard to use numerical methods in a step-by-step calculation. (Piecewise Linear) . Excel will do this for you very well and give you a graph at the same time as long as you just want to show the path, given initial conditions. It's a bit harder if you want to determine how to aim at a particular target. That would need some iterative method and the use of a programming language, I think. (Though you can get Excel to solve some equations). Modern PCs have enough grunt as long as you don't need real-time answers.
if you choose drag force proportional to the velocity squared, and the only other force is gravity, then even though it is a non-linear differential equation, there is an exact solution. This is because the equation is an example of a family of equations known as Bernoulli differential equations. (And they all happen to have nice solutions).
But, if you want a more complicated drag force, or if you start including other forces, then I can't guarantee there will be a nice solution. In this case, you can do as others have suggested and look for the behaviour numerically.
Thanks for the steers in the right way. I was actually looking to build a simple Java application to do this for me, but have been struggling to understand the variables required and the math that then needs applying to these variables.
I will do a bit of work looking at Bernoulli differential equations.
I know its a bit of an ask, but any chance someone could post here a simple example equation using piecewise linear and Bernoulli differential equations? Thanks for the help so far.
the standard way to do the numerical simulation is by Euler's method: http://en.wikipedia.org/wiki/Euler_method Essentially, you say that at each time step, the position is updated by v * dt (where v is the current velocity and dt is just a small constant number, for example 0.001, note: the smaller you make this number, the better the approximation) And also, at each time step, you need to update the velocity and acceleration. a * dt is the velocity update, and the acceleration is updated in whatever way satisfies Newton's laws. For example, if the Newton's law for your model are like this: ma = -Cv^2 -mg (where C is just a constant), then 'a' just gets updated using this equation, using the new value of 'v'.
20K
28K
  • · Replies 16 ·
