How can I calculate binodal line T-V with simulation result?
  • Thread starter Thread starter quin
    Line Simulation
To calculate the binodal line for a phase diagram using NVT simulation results, it's essential to consult relevant literature on phase diagram computation in atomistic simulations. Key works include those by Carlos Vega, which focus on phase diagrams using classical potentials, and David Kofke, who addresses general theory and numerical issues. Constructing the binodal line typically requires multiple simulations across the entire phase diagram, although some methods may allow for its construction from a single simulation, as discussed by Sidney Yip and Antonelli. For a comprehensive overview, the book "Understanding Molecular Simulation" is recommended. Thorough research and multiple simulations are crucial for accurate phase diagram representation.
quin
Hi all
I am running a NVT simulation for some structure and want to draw the phase diagram for T vs V.
In my code I set some special value for temperature and also for volume. Also I have the analytic formula for my interaction potential.
But I don't know how I can draw the binodal line for phase diagram.
Would you please help me with this issue?
Thanks for your favor.
This is not a simple question that can be answered in a forum post. Best thing is to consult literature about computing phase diagrams using atomistic simulation. The work of Carlos Vega et al focuses on the phase diagram of water using classical potentials. Consult some of his work. For the general theory and numerical issues consult the work of David Kofke.
Also notice that this construction usually requires multiple simulations spanning the whole phase diagram for all possible phases. So this is usually a thorough work. However, I have vague memory of few papers that discuss possible methods to construct the coexistense line for two phases using a single simulation. Check the work of Sidney Yip and Antonelli on this matter.
You might also find a concise summary of the whole topic in the text "understanding moleculer simulation"
https://www.amazon.com/dp/0122673514/?tag=pfamazon01-20
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 0 ·
