How can I calculate the work done in a gas compression problem?
  • Thread starter Thread starter BrainMan
    Compression Gas
The discussion revolves around calculating the work done in a gas compression problem, specifically involving an ideal diatomic gas. The original poster attempts to determine the change in thermal energy and work done during the process, referencing relevant equations and attempting calculations based on pressure and temperature changes.
  • Participants discuss the calculation of thermal energy and the need for the specific heat capacity (Cv) of a diatomic gas. Questions arise regarding the general equation for work done in a P-V context and the methods to calculate it, including integration and graphical interpretation.
Some participants provide guidance on the value of Cv for diatomic gases and clarify the relationship between the integral of pressure and volume and the area under the P-V diagram. There is an acknowledgment of the original poster's confusion regarding the work calculation methods, with suggestions to explore further in upcoming course material.
Participants note that the original poster is uncertain about the specific heat capacity and the methods for calculating work, indicating a potential gap in the course material that will be addressed in future chapters.
BrainMan
ΔEth = nCvΔT
W = -∫ p dV
pV = nRT
I tried to find the total change in thermal energy by finding the temperature change.
I first found the initial pressure
P1 = nRT/V = 32464.4 Pa
Then I solved for the final pressure
p1V12 = p2V22
p1V12 / V22 = p2 = 292179.6 Pa
Then I found the final temperature
T2 = pV/nR = 879 K
What I wanted to do next was use ΔEth = nCvΔT to find the total thermal energy and then subtract the work to find the heat. Unfortunately, I don't know what Cv is equal to or how to find the work.
What is Cv for a diatomic gas? What is the general equation for the amount of P-V work done on the surroundings?
Cv is one the things that is confusing me. In my book it has a table for a couple of Cv's for different gases so I'm not sure which to use.
https://lh3.googleusercontent.com/Rv3s5lQ2vyLKOnlbAg64OHbFcNAw_pmlo3t_v1YoFHulQit7hmXE3QNfhnkkY2CkbFphumXv2Fur1BgU6j7CJ2ndcsMKnvvKsKTcS0La7W1cMEUdeQQ3FbwVGqP5uWtq6m-kac0EcRYm_z-pHDVDPFX_KTcGziQOZQlpRX-c_lkY1xWJEPMQcEwFIdgZ7kYoCr9xMVr0IzzS4h_1xe3yKY4GOsox4ARm5AfFURq_crZHRoHdsGH9XYU8hyrFe2AFoDavbMAn2ee_h3yrviHDKjvCau1GbRp6K7xKT5ql1j64izFwZO32BxrpXCMhI5CEMjMnIc5hN6-259RsF8SsgIiZxsnQD7TAu3-9d8Xj3vMR35dMFtUUSelQQqWnQblf0ylCU0DYrzG9N2Mfx3g3_WlsPUZkkoEKP9dmSO8HU0KEfev7mT2Xz8cB2mcGLaFXeywOdi0kWonRkAfn1XG3mGgT2S4j0GWWMPL-AZpMb5RgzYHMe_HFK0oKB18wEPGsX3PAGwTh8yoklqY_TLssNCRJeLLKTYIhXf1Pl7LHumgHEHRrhfuHt0ZtmZ5AEQKq64Nooh5rsHMRfAGXyvQP6SdsadwWXxxc2evTNwlvnTGZRg9ucT4P=w619-h662-no
For an ideal diatomic gas, the molar Cv is equal to 5R/2. Did they not cover this in your course?
I looked ahead and it seems it will be covered in the next chapter. OK so that solves that problem. What I'm wondering about now is the work. My book wasn't very clear about work and the two ways it gave to calculate work were to W = -∫ p dV or to find the area under the curve of the pV diagram.
The equation you wrote for the work represents the work done by the surroundings on the system. This equation is correct. You are aware that the integral of PdV is the same as the area under the curve of the pV diagram, correct? In this problem, to get the work, you are going to have to integrate pdV.
