How Can I Easily Tackle Binary and Hexadecimal Problems?
Amathproblem22
I don't need help with a problem just help with easy ways of tackling the problems. Below are my current methods. (Hopefully, all is correct I was in a rush).
Binary to Decimal:
1286432168421
11110001
I already know $$128+64+32= 224$$ so then $$ 16+1=17$$, meaning $$224+17=241$$
Decimal to Binary:
$$79$$
1286432168421
01001111
So I do this by basically figuring what adds up to 79 or by figuring if the number can fit into any (hopefully that makes sense).
Binary to Hexadecimal:
84218421
10100101
I break it up into two sets of 8-4-2-1 and add up the 1's below it accordingly. $$10=A$$ in the first column, and $$5$$ in the scond column so $$A5$$
Hexadecimal to Binary:
$$B4$$
$$B=11,4=4$$ so I but ones in the columns above so it adds up to the desired numbers leaving me 10110100.
Hexadecimal to Decimal
Using B4 from above = 11, then times that by 16 which in this case is easy and = 176 then adding 4 = 180
The simplest way to change decimal to binary repeated division by 2. 79/2= 39 with remainder 1. 39/2= 19 with remainder 1. 19/2= 9 with remainder 1. 9/2= 4 with remainder 1. 4/2= 2 with remainder 0, 2/2= 1 with remainder 0 1/2= 0 with remainder . So 79= 100111. Notice that "1"s and "0"s are the reverse of those calculations.
Binary to hexadecimal is easy because 16= 2^4 = 10000 in binary. Divide the binary number into groups of 4 digits: 10100101= 1010 0101. Yes, 1010 is 8+2= 10 which is represented by "A" in hexadecimal and 0101 is 4+ 2= 6. 10100101 in binary is A6 in hexadecimal.
To go from hexadecimal to binary is also easy- convert each hexadecimal "digit" to binary.
B= 8+ 3= 1011 and 4 is 0100 so B4 is 10110100.
For something more complicated, E423BF: E= 8+ 4+ 2= 1110. 4= 0100, 2= 0010, 3= 0011, B= 1011, and F is 1111 so E423BF is 111001000010001110111111 in base 2.
This is an easier version of what you were saying I guess halving by two and put a 1 if the number above is odd and a 0 if the number is 0.
01249193979
01001111
Assuming you added A6 wrong? and dropped a 1 off 100111? Or was I wrong lol
Except that I would never say "halving by 2" (what else can you halve by?) that is essentially what I said.
