How can I implement a website using HTML and CSS without functionality?
187 replies · 14K views
Klaas van Aarsen said:
I think we cannot test php on w3schools. :unsure:
We may need our own server that executes our php code. 🤔
Then again, there may be online php test locations.
Do I have to download something? Or how does this work? 🧐
I've found a php compiler on w3schools now.
However, it doesn't seem to give us the option to create an html form and submit from there. :unsure:
If we want our own local web server, we can install apache. 🤔
I have Apache installed on my system and I was able to create a search box so that the submit button runs a php script in cgi-bin:
:cool:
https://www.physicsforums.com/attachments/11046
:cool:
Downloading Apache we get a file Apache -> httpd-2.4.35 -> httpd-2.4.35-o102p-x64-vc14 (and one httpd-2.4.35-o102p-x86-vc14 ) -> Apache24. In the last one there are several files. Do we save the php file that we write in the file "cgi-bin"? And where do we save the html file? Also there? 🧐
The html file should go to something like a /www/html/ directory, where there should already be an index.html file. 🤔
In the Apache24 file there is "htdocs" which includes an index.html file. Do you mean to save my html file there? :unsure:
Yep. (Nod)
Yep. (Nod)
It doesn't work (Sweating)
I get:
I saved the two files like this:
Is this wrong? 🧐
evinda said:
It doesn't work
Is this wrong?
That is correct. (Nod)
What do you get if you open http://localhost or http://localhost/index.html in your browser? 🤔
If Apache is working you should get a standard apache html page that shows 'It works!'
If that works, what do you get if you open http://localhost/example.html? 🤔
It doesn't work... I get:
evinda said:
It doesn't wotk. I get:
Then you're not running apache yet.
Can you open the apache application?
Apparently one way to do it on Windows, is to open a command prompt, and type:
Code:
cd ...\Apache24\bin
httpd.exe
where ... should be replaced by the location where you have Apache.
It's explained in the readme_first.html file that is in the top directory. 🤔
Code:
cd ...\Apache24\bin
httpd.exe
Which of the following files do we use? 🤔
Those look the same. :unsure:
Perhaps one of them is a .zip file and the other is the unzipped version.
In that case we need the one that is unzipped.
Either way, we'll find out if we open a command prompt. 🤔
If I do it on my Windows I get:
Oh wait. (Wait)
I see now that one is for x64 and the other is for x86.
The first would be a 64-bit version and the other is a 32-bit version.
Either should work. 🤔
I get:
httpd: Syntax error on line 39 of C:/Users/evinda/Desktop/Apache/httpd-2.4.35/httpd-2.4.35-o102p-x86-vc14/Apache24/conf/httpd.conf: ServerRoot must be a valid directory
evinda said:
I get:
We have to edit that httpd.conf file.
It contains
Code:
Define SRVROOT "/Apache24"
I've changed mine to:
Code:
Define SRVROOT "C:\Users\vanaarse\Downloads\httpd-2.4.46-o111k-x86-vc15\Apache24"
and it works now. 🤔
Code:
and it works now. 🤔
So we just write "C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24>"... We don't have to edit something else, do we? 🧐
When we get no error, it means that it works, right? 🤔
What do we do next? 🧐
What do we do next?
Open http://localhost in your browser and see if an apache web page shows up.
And if you have your example.html in the correct htdocs directory, we can also try http://localhost/example.html. 🤔
Btw, there should not be a '>' at the end of the path. :eek:
I open http://localhost and I get:
So it still doesn't work, right? (Sweating)
I wrote:
cd C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24
and I got:
C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24> 🧐
and I got:
Yes, but the '>' is not part of the path and must not be in the httpd.conf file.
It seems likely that is the reason that it does not work yet. 🤔
Furthermore, in the Apache24 directory there is a 'logs' directory that contains the file 'error.log'.
It will contain a line at the end that clarifies why apache does not work yet. 🤔
In Apache directory I have:
In the log directory I have:
There is also a error directory which contains:
Ah, the error.log is not there yet because the path is wrong, so Apache can't write error.log to its proper location yet.
If we fix the path and run httpd.exe again, then the error.log file will appear in the 'logs' directory. 🤔
I wrote now:
C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24\conf>httpd.conf
and then I got:
So Apache is working now, or not? 🧐
evinda said:
I wrote now:
and then I got:
I'm afraid not. :oops:
Let's go through it step by step.
  1. We start with the command prompt that you have.
    It shows C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24\conf>.
  2. Type C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24\conf> notepad httpd.conf, which will open the configuration file in notepad.
  3. Near the top, which is also in your first screenshot, there is a line that reads Define SRVROOT "/Apache24".
    Change that line to Define SRVROOT "C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24"
  4. Save the file and close notepad.
  5. Type C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24\conf> cd ..\bin.
  6. Type C:\Users\evinda\Desktop\Apache\httpd-2.4.35\httpd-2.4.35-o102p-x86-vc14\Apache24\bin> httpd.exe, which should start apache.
    The prompt will not return.
    Later on, if we want to, we can stop apache by pressing Ctrl+C, after which the prompt will return.
  7. Check if we can open http://localhost in the browser.
(Sweating)
(Sweating)
It works now! (Clapping)
So to run the program I save the html file in the "htdocs" directory and the php in the "cgi-bin" directory, right? 🧐
evinda said:
It works now!
Nice. (Sun)
Yep. (Nod)
Yep. (Nod)
I open http://localhost/example.html and after giving the input I get:
I saved the two files as follows in the directory we said in the previous post:
At the logs directory there is now a file with the name "error":
And in this file I get:
[Sun Apr 04 01:51:22.887386 2021] [ssl:warn] [pid 17024:tid 540] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Sun Apr 04 01:51:23.427353 2021] [ssl:warn] [pid 17024:tid 540] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Sun Apr 04 01:51:23.428355 2021] [mpm_winnt:notice] [pid 17024:tid 540] AH00455: Apache/2.4.35 (Win32) OpenSSL/1.0.2p configured -- resuming normal operations
[Sun Apr 04 01:51:23.428355 2021] [mpm_winnt:notice] [pid 17024:tid 540] AH00456: Server built: Sep 17 2018 21:34:44
[Sun Apr 04 01:51:23.428355 2021] [core:notice] [pid 17024:tid 540] AH00094: Command line: 'httpd.exe -d C:/Users/evinda/Desktop/Apache/httpd-2.4.35/httpd-2.4.35-o102p-x86-vc14/Apache24'
[Sun Apr 04 01:51:23.541351 2021] [mpm_winnt:notice] [pid 17024:tid 540] AH00418: Parent: Created child process 15708
[Sun Apr 04 01:51:26.324483 2021] [ssl:warn] [pid 15708:tid 584] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Sun Apr 04 01:51:26.496066 2021] [ssl:warn] [pid 15708:tid 584] AH01909: localhost:443:0 server certificate does NOT include an ID which matches the server name
[Sun Apr 04 01:51:26.501077 2021] [mpm_winnt:notice] [pid 15708:tid 584] AH00354: Child: Starting 64 worker threads. (Sweating)(Sweating)(Sweating)
It seems there is nothing relevant in the error.log file at this time. :confused:
What is the address in your browser after you submit the input?
Perhaps it does not match the location of the .php file?
It should be http://localhost/cgi-bin/action.php. 🤔
No, it is http://localhost/action.php 🧐
It is correct then that it cannot find it. 🧐
We need to modify example.html so that it says action="cgi-bin/action.php". (Sweating)
