Fortran How can I improve my Fortran program to factor numbers?
  • Thread starter Thread starter Jeepster
    Factoring Fortran
The discussion revolves around a Fortran program designed to factor a number greater than one. The initial implementation successfully factors numbers but outputs each factor separately, while the desired output format is a single string representing the factorization, such as "2**3*3*5**2" for the input 600. To achieve this, a suggestion is made to introduce an inner loop that counts the occurrences of each factor and stores this count in a variable. The output should reflect single occurrences with a "*", while multiple occurrences should be formatted with "**" followed by the exponent. The user encounters an error related to the format statement in the second version of the program, specifically with the format specifier (I2, A2, I2). This indicates a need for correction in the format string to properly display the factors and their counts. The urgency of the request highlights the need for a quick resolution to meet a deadline.
Jeepster
Got to write a program that factors a given number(>1)
Here is what I have:
program Factors
implicit none
real::n, i
print*, "enter a number:"
read*, n
i=2
do while (n>1)
if (mod(n, i)==0) then
i=i+1
n=n/i
else
write (*,*) ' X= ', X
end if
end do
end program
It works great but let's say you put in 600, it will give
which is right but the teacher wants it to say:
2**3*3*5**2
I don't have a clue how to make it do that.
Thanks for any help. :)
Technology news on Phys.org
You'll need an inner loop that counts how many times a given factor is used, storing that in another variable. If it's used once write it with a "*", otherwise write it with a "**", the exponent, then another "*".
ok. I put this together but I am getting an error
program Factors
implicit none
real::n, i, x
integer::f, c=20
print*, "enter a positive integer:"
read*, n
i=2
do while (n>1)
i=i+1
n=n/i
else
write(*, 100) i, "**", c
100 format(I2, A2, I2, $)
end if
end do
end program
I know I just signed up but this thing is due in a few hours.
Any help is much appreciated.
well what's the error?
It says there is an error in the (I2, A2, I2, $). It has an arrow pointing to the first I2.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
