How can I make x the subject of y = ~5/1-x?
  • Thread starter Thread starter White Rabbit
The discussion centers on solving the equation y = √(5/(1-x)) for x. Participants emphasize the importance of manipulating equations correctly, particularly the necessity of performing the same operation on both sides to maintain equality. Key steps include squaring both sides to eliminate the square root, leading to the equation y² = 5/(1-x). The final solution for x is expressed as x = 1 - 5/y². The conversation highlights the significance of understanding square roots and exponents in algebra.
  • Understanding of algebraic manipulation
  • Familiarity with square roots and their properties
  • Knowledge of exponents and their rules
  • Basic equation solving techniques
  • Study the properties of square roots and exponents in algebra
  • Practice solving equations involving square roots
  • Learn about the transitive property of equality in mathematics
  • Explore online resources for algebra tutorials, such as Khan Academy or Mathway
Students returning to mathematics after a long break, tutors assisting learners in algebra, and anyone seeking to strengthen their understanding of manipulating algebraic equations.
White Rabbit
Hi guys.
I have just recently gone back to school and I'm having some problems with "assumed knowledge" . They assume that I actually have some maths knowledge but it has been nearly 20 years since I have done any of this so the knowledge that I had has long since evaporated.
I'm having a problem with this equation.
I have to make x the subject. y=~5/1-x
~ means square root
There is an image of the equation here that I put up in case you can't decipher my translation up top.
http://i174.photobucket.com/albums/w120/sandy_brown73/y51x.gif?t=1176429869
I'd like an explanation on how to solve this myself rather than giving me the answer as I need to know this for myself.
Any help would be much appreciated.
Thanks
A good start would be to square both sides. See if you can go from there.
I'm not sure if this will work but...
How does this look?
y = ~5/(1-x)
y= 5 squared / (1-x) squared
y = 25 / (1-x) squared
y/(1-x) squared = 25
(1-x) squared = 25y
(1-x) = ~25y
x = ~25y+1
Thanks
Whatever you do to one side of the equal sign, you MUST do to the other, if you want to maintain that equality.
Furthermore, if you square
\sqrt{\frac{5}{1-x}},
do you really get
\frac{5^2}{(1-x)^2}
? :smile:Here's something to think about:
You have
y = \sqrt{\frac{5}{1-x}}.
So, y is something remotely like \sqrt{1/x}. If y is remotely like the square root of something, then that other thing must be remotely like the square of y. In other words, you should expect 1/x to be something remotely like y^2, and so x should be remotely like 1/y^2.
Once you learn how to manipulate these things, arguments like the one I just made won't be needed for simple problems. However, they are sometimes still useful to get a rough idea of how an answer should look in much more complex problems.
Here's a little bit of a tutorial on manipulating equations, since you seem to be a little bit rusty. :smile:
Alright, let's say we have an equation
a=b.
That means that a is the same as b.
It's worth noting a special property of equalities right away. Suppose a=b and b=c are equalities. Then a=c is also a valid equality. This is called the "transitive property," and can be very important.
Now, let's suppose a=b is an equality. I can add something else, call it c, to both sides, to get
a+c = b+c.
Since a is the same as b, it is easy to see that a+c should be the same as b+c. Thus, you can manipulate an equality by adding something to both sides, and the result will be another equality.
Similarly, you could multiply both sides by c to get
ac = bc.
Again, this is a valid equality. So far, then, given an equation, you can: 1) Add the same thing to both sides ; or, 2) Multiply both sides by the same thing; and you will keep equality.
There are other things that you can do, though. Suppose you have two equations,
a=b, \ \mbox{and } \ x = y.
Here a is the same as b, and x is the same as y. So, it certainly makes sense that ax is the same as by!
Thus we have another rule: 3) Given equalities a=b and x=y, ax=by is also a valid equality. While we're at it, we had might as well note that a+x = b+y is also clearly a valid equality!
There are some general patterns you can notice here: Suppose you have an equation a=b. As long as you do exactly the same thing to both sides of an equation, the equality remains valid. For an example: if a=b is an equality, then a^2 = b^2 is also an equality because I've done exactly the same thing to both sides.
This is subject to a many conditions, though, depending on the context. For example, suppose a=b is an equality. Is 1/a = 1/b a valid equality also? The answer is almost always yes. When is the answer no? Well, what if a=0? Then b=0 also, since a=b. But 1/0 is undefined. So, if a=0, then 1/a = 1/b doesn't mean anything at all (it says that two undefined quantities are equal, which is fairly meaningless).
There are other such conditions depending on what you want to do to both sides. Explaining why, and how to deal with them, would take too much time for me to do here; if you have questions, I suggest asking the instructor of your course for some help.
There's also the second pattern. If a=b and x=y are equations, then you can use x the same way as y when you're manipulating a=b. Thus, for example, x/a = y/b is also an equality, as long as a \neq 0 (read: a is not equal to 0). Similarly a^x = b^y is also a valid equality, etc.For now though, you should remember the fundamental rule: In general, when manipulating an equation, you must do the same thing to both sides at each step.
You have great freedom in what you can do to the equation. But you have to do the same thing to each side, or else the result just isn't an equality anymore!
do you really get
\frac{5^2}{(1-x)^2}
To build off what he said or if you still don't get it, consider this:
\sqrt{\frac{5}{1-x}}, is the same as: ({\frac{5}{1-x}})^{1/2}
So if you were to square that what would you get?
y^2 = \frac{5}{1-x} (square both sides)
(1-x)(y^2) = 5 (times by 1-x)
-x = \[ (\frac{5}{y^2}) - 1\] (divide by y^2 and subtract 1 to get x by itself)
x = 1 - \frac{5}{y^2} where y \ge 0
Wow, thanks guys I think I actually get it, how about that. I see where I was going wrong with the squaring. Like I said it's been a loooong time since I was in school, infact I don't even remeber any of this from school.
Thanks
Again.
Would there be any chance of putting up some more of these types of equations for me so that I can see if I do get it.
Or can you point me in the directions of a site that would have some.
Thanks.
When you square both sides it undoes the RHS in the original equation:
(\sqrt{x})^2 = x
Here's what Feldoh was talking about.
x^\frac{m}{n} = \[ (x^\frac{1}{n})^m\] =
(x^m)^\frac{1}{n} =
= \[(\sqrt[n]{x})^m = \sqrt[n]{x^m}
What you need is an algebra cheat sheet.
White Rabbit: Consider \sqrt{2}. What's (\sqrt{2})^2?
=2.
Thanks, now I understand, when you multiply a square root by itself you eliminate the square root.
so (\sqrt{\frac{5}{1-x}})^2, is 5/1-x and not 5/1-x times 5/1-x because that would give you 25/1-x. Or 25/1-x^2?
Thanks
You're not squaring the 5/(1-x), you're squaring the sqrt(5/1-x). In the process of involution (repeated multiplication), you're multiplying a quantity by itself the number of times indicated by the exponent.
x^3
3 is the exponent. so it means x * x * x
A law of exponents state that you add the exponents when you multiply so x ^1 * x^ 1 * x^1 = x ^3
Perhaps you might think of it as you square the 5/(1-x), and you get your second answer -- assuming you mean 5^2/(1-x) -- and then if you take the square root of that, you get the 5/(1-x).
what math are you in if you don't mind me asking?
edit -- "assuming you mean 5^2/(1-x)^2"
Thanks.
http://www.bymath.com/studyguide/alg/alg_topics.html#Principles (Relevant chapter found http://www.bymath.com/studyguide/alg/sec/alg17.html)
Introduction to Mathematics and Algebra
But really, nothing beats a good book (with answers to some of the problems to check yourself on). :smile:
The maths course I'm doing is a uni prep class one night a week. I'm not the only one that is stuggling with the course though. The problem I have is that there is some assumed knowledge, as you can see I have no maths background. Having said that, I'm not struggling with all the course but just square roots as they are assumed knowledge. It's something i need to get my head around because the keep cropping up.
The subjects that I have covered so far are expanding, percentages, factoring, geometry, equations (last week) and a few others. We basically cover one or two of these subjects a week so it's pretty fast, and not well taught in my opinion and the opinion of just about everyone I've spoken to. I don't actully get much out of the class because they fly through it. There is only time to write it down but not to understand, but I guess that's UNI so I should get use to it.
This is revision of the stuff we will need before starting calculus. Like I said most of it I'm ok with but square roots have not be taught at all.
Thanks
x^3
Thanks, I understand exponants. What was tripping me up was the square root. But I understand now that by squaring the root by itself you eliminate it.
And thanks for the links.
A square root is an exponent, though!
\sqrt{a} = a^{\frac{1}{2}}.
If you understand the rules for exponents then it's easy to see how to square a square root. :wink:
Another thing to be careful of is when you take the square root of both sides of an equation.
\sqrt{x^2} doesn't equal x, it equals the absolute value of x
\sqrt{(-2)^2} = |-2| = 2
If you have:
x^2 = 4 and take the square root, you should get x = +/-2 because
\sqrt{x^2} = 2 = |x|
Hi Guys.
Just wanted to say thanks for the help. I bit the bullet and hired a tutor, and it did wonders for my understanding.
My biggest problem is the speed in which the class progresses, and I am finding that I'm left with big gaps in my understanding. The tutor helped me fill in some of the blanks that I have. I have him booked in twice a week for the next month just get me up to speed.
Again thanks.
Sandy
